Old 02-23-2023, 11:15 AM   #15
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by Neinris View Post
Remember, the adaptor plates were originally meant for the Corolla calipers, and I knew that the Yaris calipers would also works, because their rotors diameters are the same, therefore the caliper diameter are also the same. It's just that the Yaris' calipers are clocked directly to the rear (3 & 9 o'clock), while the Corolla's are clocked up (around 2 & 10 o'clock). And the Corolla's parking brake cable will be mounted on the top, farther away from the road and dirt. Less chance of seizing?
I thought of the same thing as you said, that's why I went ahead and bought the Yaris calipers, but I got to thinking how much convenient the Corolla's design is. I will show everyone what I mean how much easier it is to replace the brake pads when the Corolla calipers are used. Again, only if the route for the parking brake cables works out. We'll see this weekend.
Yeah just go yari brakes they are oem the parts will fit, we know they work mint, will have hose connections at correct angles too and yeah the handbrakes..Keep it simple hahaha
Compeer is offline   Reply With Quote
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
