Old 04-23-2023, 02:31 PM   #31
sh0rtlife
local yard has an XD and an XB1 hitting the yard soo...so if they hit while the XB2 is still in the yard i can compare those if we can verify that either of them is the same as a yaris
on a side note..since i had to pull a hub off the xb2 out there....i made a note, if someone wanted discs on a quick n dirty you could cut off the axle ends, grind em flush, get longer bolts, and just sandwich those plates into your existing axle tube..giving you 1/2inch offset and disc brakes all in one fell swoop....the hubs are just long to still locate thru the new flange and into the one still welded to your axle
now i need to find a 4x100 version to do some 14innch wheel clearance tests!!!!!!....prius's are NOT hitting my yards and i was unde rthe impression thats the only place to get the 4x100 factory discs(aside form a yaris RS which may as well not exist)
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
