Old 05-14-2023, 06:02 PM   #1
ltwargssf
Drives: yaris
Originally Posted by mitch9521 View Post
I was able to pop mine off with just some thumb force. But yes I agree, these bushings coupled with my TRD quick shift assembly from Japan and weighted shift knob make a world of difference. Now I need to address the shit garbage stock 3.72FD in the transmission and replace it with a 4.31FD + C59 5th gear
I drove my friends matrix swapped with the C60 and honestly, even he regretted the swap because of the shorter gears and having to constantly shift compared to the longer gears in the 5 speed. On a track its for sure better but if all you do is daily drive and don't track it, you will just get more annoyed with the amount of extra shifting.
The 6th gear is the same as your 5th anyway so you don't benefit from lower rpms, is the C59 fifth gear taller? If so what you mentioned sounds like the perfect solution to the 5 speed, shorter 1st and maybe even 2nd gear but have a taller 5th gear to reduce highway rpms.
ltwargssf is offline   Reply With Quote
Old 05-15-2023, 06:33 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
C59 5th gear is 0.725:1
C50 5th gear is 0.815:1
With the 4.31 final drive, the longer C59 5th gear drops the cruising RPM to around where the stock 3.72 would be at with the 0.815 5th gear, give or take a couple hundred rpm.
Extra shifting doesn't bother me, I love driving stick, every aspect of it. Its just muscle memory at this point lol
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Shifter cage bushings? Caramanos2000 Performance Modifications 6 12-05-2014 06:59 PM
The MI SSK "Not a Big 'Car Guy'" Review jpmck03 Performance Modifications 36 09-19-2013 11:41 PM
TRD SSK & Shift Cable Bushings Issue/Question minnyar Performance Modifications 5 04-14-2010 10:50 PM
Bronzoil Cable Bushings for the Yaris/Echo now available! TWM Performance TWM Performance 58 03-31-2010 10:19 AM
NST shifter cable bushing users: Lube up! schleppy Performance Modifications 11 07-05-2009 08:47 PM
