Old 09-09-2025, 11:34 AM   #1
komichal
What codes are you getting? Is it always the same code or are you getting multiple codes?
I would be interested in the rollover valve - if is working properly. Maybe with a full tank it leaks gas to canister?
How about filling the tank up just to a half or so. If you keep doing it this way, does the error come back? If not then my bet would be on the rollover valve.
cel, charcoal canister, evap, hard start, purge valve
EVAP canister - 2012 Yaris calyaris DIY / Maintenance / Service 3 07-27-2022 03:43 PM
EVAP leak detected? eepp DIY / Maintenance / Service 7 01-29-2018 12:42 AM
New question evap canister replacement Rutherford DIY / Maintenance / Service 3 02-06-2014 01:16 PM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
