Old 05-14-2007, 04:09 AM   #1
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Originally Posted by beep View Post
I pretty sure the rattling comes from engine bay not from the fan below the filter housing but I will check it too.
Another thing is that rattling stops when I rev the engine a little bit.
Oh. you where told it is possibly a heat shield on your exhaust? If so then it might be a bracket that is cracked on the heat shield. That same thing occured to me several years ago on another vehicle. I just pulled the shield of and had it welded.
BTW, how many miles on your car?
blacksan is offline   Reply With Quote
Old 05-14-2007, 03:39 PM   #2
beep
Drives: Yaris TS
The car has around 50.000 mileage now.
I went to a local toyota garage and they told me it could be the compressor but they are not sure as the rattling didn't happen when I was there. It is strange to blame compressor as the rattling stops when I rev the engine a bit
beep is offline   Reply With Quote
Old 05-14-2007, 04:24 PM   #3
blacksan
blacksan's Avatar
If the AC compressor is making noise it might not have enough refrigerant in the system. Do you ever have the AC serviced before?
Old 05-14-2007, 05:51 PM   #4
beep
Drives: Yaris TS
Yes, I have it serviced 2 months ago.
Old 05-14-2007, 07:59 PM   #5
blacksan
blacksan's Avatar
Did it rattle before that service?
Old 05-15-2007, 03:27 AM   #6
beep
Drives: Yaris TS
Yes it did
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
A/c blower motor noise!!!! LBdriver General Yaris / Vitz Discussion 28 09-12-2007 07:46 AM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
