Old 06-07-2007, 12:34 PM   #1
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
the valve train noise you are hearing is normal, and means that your engine is functioning properly. start worrying if mpg's drop, or large chuncks of metal are found in the engine oil.
otherwise, everything is a-ok. I've owned 3 toyotas. A '87 pickup, a '94 corrolla, and my '07 yaris. The first two had over 200,000 miles, and made similar clicking noises...it is a toyota engine attribute that takes some getting used to.
fu_im_from_texas is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? oscarying Performance Modifications 25 10-21-2006 09:42 PM
