Old 06-12-2007, 06:26 PM   #1
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Thats 106 bhp. It has about 90ish whp. :)
Here you be...
http://www.yarisworld.com/forums/showthread.php?t=6338
Old 06-12-2007, 06:56 PM   #2
kurokoma-kun
Drives: 2007 Yaris HB
If you are comparing models before buying though, you are most likely going to see all hp numbers expressed as whp, or at least that's what I was looking at before I bought.
my yaris, kurokoma-kun
Old 06-12-2007, 06:58 PM   #3
staticorex
staticorex's Avatar
hp at the dealership is in bhp.
Old 06-12-2007, 07:10 PM   #4
kurokoma-kun
I'm sure you are right, I guess we must have getting info from different sources. For example, one place I looked was Toyota website, and 106hp is what they show under specs; actually, everything I looked at online had the same figures. Since this is the info I used to compare cars I just thought redduck might find it useful.
Old 06-13-2007, 12:14 PM   #5
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Almost exclusivly, hp is expressed as flywheel horsepower. Thats what manufacturers report, thats what magazines use.
Auto Dynos however report wheel horsepower (whp, or fwhp or rwhp for front or rear wheel hp). A very expensive engine dyno will tell flywheel hp - and you have to test the engine out of the car for obvious reasons. The reason manufacturers give flywheel hp is because they test the output of the engine in R&D and engineering, not after the car is assembled.
WRBlue is offline   Reply With Quote
Old 06-18-2007, 07:37 AM   #6
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Here you be...
Exactly!
So many questions... ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 15 12-16-2008 06:52 AM
Performance Noob Questions fatjerkgary Performance Modifications 20 05-11-2007 10:20 AM
Few questions mystikdynasty03 Cosmetic Modifications (Exterior/Interior) 3 05-01-2007 07:42 PM
Newbie Questions jenna Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 03-27-2007 01:04 AM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
