Old 07-05-2007, 02:14 PM   #14
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
of sorry didnt mean to confuse you..but think about if benz c230 kompressor supercahrge got bigger engine using synthetic oil and changing it once per year....and our yaris got 1.5 l engine...wouldnt that make the oil last longer on ours then..TADA!!!
All I meant was that the Benz was a far more expensive, higher compression, and tighter tolerance design, therefore, it would make sense that the engine was built to handle those changes. The Yaris is just our little grocery-getter, and should be maintained and more frequent intervals. I'm probably foolish to think that, and you're probably right: I've more than likely been tossing my cash senselessly. But, it helps me sleep better at nite...
YarisTom73 is offline   Reply With Quote
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-23-2008 11:45 PM
Oil and Filter Change jonr0613 DIY / Maintenance / Service 6 02-10-2007 07:12 AM
oil change question chickmagnet8301 DIY / Maintenance / Service 8 01-21-2007 02:13 PM
don't think the dealer changed oil filter on first change gonzo452001 DIY / Maintenance / Service 0 01-13-2007 11:44 AM
