Old 08-03-2007, 06:10 PM   #10
shoebox
Drives: white '07 Yaris Liftback
Not as tall as voodoo22, but I did this. Took out the front mount bolts, bought 1 inch longer, grade 8 or better replacement bolts, 2 ea, allen head, used a stack of flat washers, about 5/8, to 3/4 inch, wrap in black electrical tape, so they don't end up all over the floor. Rear mount bolts have to come out as well, but can be used over. You must elongate the rear mounting holes, in the rear of the track with a round (rat tail) file. The front bolts go in at an angle, so the more spacers you use, the more you have to elongate the rear seat track holes. You will need a special female torx socket, I think #10, to remove the stock mount bolts. This change of seat angle, makes a big difference in thigh support, and comfort
shoebox is offline   Reply With Quote
front seat room Bigdaddy727705 General Yaris / Vitz Discussion 9 10-30-2013 11:26 AM
Yaris's room in the rear? feddup New YARIS Purchase Forum 8 07-18-2007 11:44 PM
Yaris chat room.... jdubau55 Off-topic / Other Cars / Everything else Discussions 9 03-06-2007 08:37 PM
Power Windows Leg Room nwdixieboy General Yaris / Vitz Discussion 9 04-06-2006 07:19 AM
ok so weve discussed the interior room on... p2filz General Yaris / Vitz Discussion 5 03-16-2006 07:54 PM
