Old 10-25-2015, 07:45 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by valchrist90731 View Post
If your grinding while shifting into reverse. Learn from your mistakes. Put the car into first gear then shift it in reverse. Grinding is due to the driver most of the time.
Have patience with your car and it will drive smoother.
This was to inform all on how to reduce grinding when shifting into reverse.
This was written respectfully as possible.
I will be as respectful as possible as well. This issue with shifting into reverse with the stock or other conventional fluod is a known issue. Expecting someone to shift into first just to shift into reverse is unacceptable. Telling someone to be patient isn't a cure to the problem. Sure, it is possible that drivers are over anxious to shift, but the issue has even been noted in published reviews. Once again reviewers could be over anxious to shift, but they have experienced many many manual transmissions in most cases so they have firm ground to stand on regarding the behavior. I have driven a few dozen different manuals from various vendors and have experienced this only on well worn transmissions not brand new ones. I had the issue within the first 1000 miles. Changed to synth and bam, resolved. There is a reason why so many manufacturers are switching to even requiring synthetic; it is a much more tolerant and better working lubricant.
Sent from my SCH-I545 using Tapatalk
Old 09-26-2009, 12:03 AM   #2
ddongbap
I'm rocking NEO oil.
Old 09-30-2009, 10:39 AM   #3
dorman68
Drives: Corolla
Great write up!!
2003 Echo - Auto Trans - 93,000 mi.
dorman68 is offline   Reply With Quote
Old 10-17-2009, 10:56 AM   #4
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
the pictures is down, can someone reupload it?
jamal1984 is offline   Reply With Quote
Old 10-30-2009, 08:28 PM   #5
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I put in AMSOIL MTG (http://www.amsoil.com/catalog.aspx?code=MTGQT-EA). I only have 9500 miles on the car, but it made a difference. There is less resistance in the gearbox at all speeds, especially low speeds. I've heard it only gets better with time.
I had access to a lift, but the job was VERY simple. I could have done it without a lift easily. Get yourself a funnel with a long tube, two quarts of fluid, and a 15/16th wrench.
It's worth doing. I'll probably change the fluid again in 20,000 miles. Why not?
Old 01-02-2010, 07:21 PM   #6
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I put it in my manual yaris I am not that impressed with it on cold morning I feel a little grind when I put it in 3rd gear until it gets warmed up I have been thinking about trying something else
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 01-02-2010, 07:35 PM   #7
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I put Redline MT-90 in this last summer and love it. And now that winter temps are here I couldn't be happier with the decision to use it. I never really notice a cold shift difference vs. warmed up like I used to. And reverse engages a lot smoother than it did before the change. Give it a try-two quarts will set you back about $22 most places.
UTVitz is offline   Reply With Quote
Old 01-03-2010, 11:35 PM   #8
Boost Addicted
Drives: 2008 Yaris 5spd, 2005 GLI 1.8T
Awesome, I was thinking of using the Redline in both her Yaris and my Jetta. I've heard good things, and I can pick it up locally for 12 bones without having to pay shipping. I'll post back up after the fluid change and tell you guy how I feel about it.
Boost Addicted is offline   Reply With Quote
Old 01-02-2010, 07:50 PM   #9
gonzo452001
I think I will
oem style foglights
Scan GaugeII
Old 01-02-2010, 08:11 PM   #10
gonzo452001
shouldn't we use the 75w90 instead of straight 90w
oem style foglights
Scan GaugeII
Old 01-02-2010, 08:26 PM   #11
gonzo452001
Ok the mt90 is 75w90 ordered 2qts from amazon
oem style foglights
Scan GaugeII
Old 01-04-2010, 11:59 PM   #12
Hershey
you won't be disappointed . Takes a little time to get the full benefit . Work through all the gears , including reverse .
Old 08-30-2010, 02:54 PM   #13
sleey0
Drives: 2008 Yaris LB
Just replaced my MT tranny oil today at 22k miles and WOW! What a damn difference.
Good to get the old gear oil out of there and some new - I bought the car used at 19k miles and who knows howthe original owner drove it or grinded 'em;) lol
REDLINE 75w90 FTW!!!
sleey0 is offline   Reply With Quote
Old 08-31-2010, 01:20 AM   #14
Hershey
It's amazing . No more grinding , smoother shifts , and no clunk into reverse . Used it in a '08 we had . Better cold shifting too . Enjoy .
Old 08-31-2010, 11:21 PM   #15
sleey0
I know it!
I really didn't think it would make a difference ESPECIALLY since the old oil that drained out was very clear and seemed still good.
I wonder what brand and type of oil Toyo uses as the factory fill for the MT tranny.
Old 09-01-2010, 02:12 AM   #16
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
^^^something that has a lot of assembly lube in it most likely....
Old 09-01-2010, 11:22 AM   #17
sleey0
Yeah, you are prob right. lol
Old 09-01-2010, 11:54 AM   #18
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Is 75w90 the correct weight for 5 speed?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 01:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
