#37 | |
![]() Drives: 2008 Yaris 5spd, 2005 GLI 1.8T Join Date: Aug 2009
It just struck me when I saw the capacity vs. what someone else put into the car after a drain. Figured I'd mention the spec.. The manual trans is 2.0 quarts or 1.9 liters. And to get to my actual point here, I'm wondering how you guys like the Royal Purple? I've heard mixed reviews... I must confess, I'm actually a Volkswagen guy (My girlfriend owns the Yaris) and people weren't too impressed with it in the 6 speed GLI's which is what I have. And I want a REALLY good synthetic for the Yaris (5 spd) because I noticed it has no syncro for reverse, and sometimes when you put it in reverse (yes, with the car stopped) it gives a quick sharp grind and kinda lurches the car slightly. Can't be good... And I don't want metal shaivings causing havoc. So what do you think is the best synthetic trans fluid out there? Thanks guys! /rant lol Last edited by Boost Addicted; 01-02-2010 at 03:27 PM. |
#38 |
![]() ![]() ![]() Drives: 3-door liftback blazing blue Join Date: Oct 2006
I put it in my manual yaris I am not that impressed with it on cold morning I feel a little grind when I put it in 3rd gear until it gets warmed up I have been thinking about trying something else
07 yaris LB 5-speed blazing Blue 07 yaris LB Auto Bayou Blue rostra cruise control oem style foglights 96tacoma 4x4 xcab I4auto Weathertech vent visors Scan GaugeII |
#39 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
I put Redline MT-90 in this last summer and love it. And now that winter temps are here I couldn't be happier with the decision to use it. I never really notice a cold shift difference vs. warmed up like I used to. And reverse engages a lot smoother than it did before the change. Give it a try-two quarts will set you back about $22 most places.
#40 |
I think I will
#41 |
shouldn't we use the 75w90 instead of straight 90w
#42 |
Ok the mt90 is 75w90 ordered 2qts from amazon
#43 | |
#44 |
you won't be disappointed . Takes a little time to get the full benefit . Work through all the gears , including reverse .
#45 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Just replaced my MT tranny oil today at 22k miles and WOW! What a damn difference.
Good to get the old gear oil out of there and some new - I bought the car used at 19k miles and who knows howthe original owner drove it or grinded 'em;) lol REDLINE 75w90 FTW!!! |
#46 |
It's amazing . No more grinding , smoother shifts , and no clunk into reverse . Used it in a '08 we had . Better cold shifting too . Enjoy
#47 |
I know it!
I really didn't think it would make a difference ESPECIALLY since the old oil that drained out was very clear and seemed still good. I wonder what brand and type of oil Toyo uses as the factory fill for the MT tranny. |
#48 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
^^^something that has a lot of assembly lube in it most likely....
#49 |
Yeah, you are prob right. lol
#50 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
Is 75w90 the correct weight for 5 speed?
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
#51 |
#52 |
Hmmm.
I used red line 75w90 that was GL-5. Is this going to be an issue? What are the drawbacks to using this oil vs. the MT-90 which is GL-4? |
#53 |
is it this one www.redlineoil.com/product.aspx?pid=47&pcid=7 or this one www.redlineoil.com/product.aspx?pid=46&pcid=7 ? If it's the 75w-90 NS GL-5 you should be fine . Says has improved copper corrosion protection for life of syncro . Give them a call at 1-800-624-7958 and ask if it's compatible with the YARIS . They're very helpful .
#54 |
It is the NS 75w90.
I'll call em up. Thanks! |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 10:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 02:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 09:37 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-08-2006 12:21 AM |
