![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Well done
. On occasion during an oil change I drop the drain bolt in the oil bucket and have to fish around for it . Keep us informed on any improvements with the new fill . Well worth the mess .
![]() Drives: Yaris 2008 Hatchback Join Date: Jun 2013
I was a bit doubtful that I would see any difference as the shift stick was moving around really well with the old oil. Well now I can hardly believe it but it is actually slicker. I would think that the biggest difference will be in winter driving.
Oh and I didn't have a 24mm socket or a 1/2" ratchet(as most 24mm sockets seemed to be 1/2" inserts). Found many at the pawn shop. Got the ratchet AND the socket for $4 all in! |
Can't go wrong at that price . Lady luck must be on your side .
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
Sorry but my Yaris is base model and didn't come with an owner's manual.
What type of fluid is recommended for the 5spd manual? Is it 75w90? thanks |
Wilbro how did your engine compartment get so dirty?
![]() I hope you changed the AF too!
![]() Drives: 2008 Yaris Sedan Join Date: Oct 2013
I was having the same problem shifting into first (at a very slow speed, maybe 2MPH?) so I found this thread and changed my gear oil to MT90 2 days ago. I cant believe how smooth it shifts now, its like butter........ BUT............. it still grinds when going into first... even when going into 2nd gear just before. Agghhhh
Let us know if the grinding disappears over a period of time .
![]() Drives: '09 Yaris 3dr HB 5sp Join Date: Aug 2009
After purchasing my 2009 3-door hatchback new and putting 165,000 miles on it I decided today (after reading this thread) to change my manual transmission fluid. I followed the advice offered by many here and would like to add a few little tips that I did that should benefit others.
I took some 2-foot long 2" x 8"'s scrap I had laying around and placed a section of 2" x 8" in front of each tire. I then drove the car onto the lumber to increase the ground clearance by another 1.5 inches. It may not sound like much but every bit helps especially when gaining access to the drain plug underneath the car without having to use a jack. I loosened-up the filler plug just enough to make sure that it could be removed, then removed the drain plug. Draining the transmission fluid without removing the filler plug prevented the transmission fluid from gushing out. After draining about a quart of fluid I then removed the filler plug to allow the transmission to drain completely. No messy spillage anywhere. I attached a clear vinyl hose 5/8"od / 1/2" id to a small funnel. The hose fit perfectly in the filler hole of the transmission - nice and snug. Unfortunately I could not find Redline MT90 anywhere locally, so I decided to use Amsoil Severe Gear SAE 75W-90. I referenced the Amsoil website to make sure it could be used in my Yaris. I test drove the car afterwards and there is a noticable difference in how the transmission shifts - nice and smooth. Thanks to all the valuable advice posted here in this thread, a job that my local Toyota dealer wanted a $198.95 to do, I did for $25.00 and it took a total of 25 minutes to do.
"Never argue with an idiot. They drag you down to their level, then beat you with experience." |
#10 | |
![]() ![]() Drives: 2008 Liftback Join Date: Nov 2010
AMSOIL lists Severe Gear as a GL-5 product. Can anyone find (in writing) where Toyota says the Yaris C50 has to have a GL-4? Just curious, I'd like to see it. When a transmission MUST have a GL-4, AMSOIL makes sure they recommend a GL-4. On the Yaris, the first recommendation is a GL-5.
AMSOIL Synthetic Lubricants Direct Jobber |
#11 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
I don't think you'll find anything in writing from the manufacturer that GL-4 is for the Yaris. It's just a general consensus that GL-4 is reviewed by members to feel better for their Yaris. If you search any of the terms ie GL-4 and you'll find that it works better for our synchros among other things.
Here is one particular thread: http://yarisworld.com/forums/showthr...highlight=gl-4 Quote:
http://yarisworld.com/forums/showthr...ht=gl-4&page=2
GL-4 is preferred . The AMSOIL Manual Transmission and Transaxles Gear Lube is GL-4 . If it's not giving poor shifting ( grinding , etc. ) you should be fine .
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
Drove my lowered sedan onto 1" thick concrete tiles at the front. Just enough space to floor jack the front up and start working. Thanks OP, you've saved me $200+ in quoted service fees, plus given me some knowledge every Yaris enthusiast should have.
For the record: Motomaster synthetic 75W90, GL-5. If our manual says says GL-4 OR GL-5, then I shouldn't worry so much about using GL-5. The Toyota engineers would be in deep trouble if they designed a gearbox without considering that they prescribed an oil grade that can harm yellow metals. |
#14 |
I looked around yesterday, and I think I found it where Cory labeled in that drawing. After removing the air box, it's visible from the top. It's an aluminum cap about 1/2" diameter and 3/4" tall. It spins freely, and I pulled it off with vise grips. It looked totally clean under the cap, but I blew it off with canned air anyway.
#15 | |
They are also used on the axles on Tacoma and tundra almost all Toyota's . sent from my S4 on Mars |
#16 |
Mine went back on just fine... what's the problem?
#17 |
No problem... Just saying no need to take it apart and risk damage yours may or maybe not ok that's all
#18 |
![]() Drives: Yaris 2010 5Dr MT Join Date: Oct 2009
Found this pdf about multiples oils. Keep in mind is sponsored by AMSOIL. Also ignore the rating at the end. Kind of crappy weighting system.
http://www.syntheticwarehouse.com/br...lube_study.pdf |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 01:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
