Old 08-23-2007, 05:50 AM   #37
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
I dont even want a new motor. Just one with like 15k miles, just past the broken in period.
I was looking to pay around 3.5k total, the same you would get with a Turbo kit, all around, a turbo kit would cost in an area of about 4k after you get the clutch, and everything, plus install.
Old 08-23-2007, 08:37 AM   #38
Black Yaris
der Zeck
Black Yaris's Avatar
Hell I can get you in under $4000, I am sure... www.copart.com find a location near you where you can pick up a donor car, it has to be picked up by a towtruck, and you have to pay, cash, certified check or moneyorder. You can not buy from the site, but I can.... just tell me when, and which auction to start watching and I will get you a car with in your budget
Old 09-17-2007, 05:35 PM   #39
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
the ecu alone is a problem with the yaris
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-17-2007, 05:44 PM   #40
Black Yaris
der Zeck
well the Engine control modual (ECM) would come out of the doner car... problem solved
when you change the engine you change the engine management to match, no problem
Old 09-17-2007, 05:50 PM   #41
KSIbucky
KSIbucky's Avatar
but would..... what about the.... and the..... ya your right ill shut up now
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 10-01-2007, 06:07 PM   #42
MPG-brian
Drives: Toyota Matrix XRS
better than 2zz...swap the 2zz into your yaris, add a hydra ems ($1500), then you can lower the 'lift'. then you will have more hp available sooner than 6400 rpm like in corolla, matrix, etc.
www.mpg-motoring.com
MPG-brian is offline   Reply With Quote
Old 10-01-2007, 06:20 PM   #43
ddongbap
Why don't we first figure out if the 2ZZ'll fit in the first place? I was contemplating this. But if the 2ZZ would require custom fab, then I might as well invest in putting in a B18.
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Aftermarket engine dipstick sroberts General Yaris / Vitz Discussion 1 08-10-2006 09:44 PM
Engine Working too hard? David81 General Yaris / Vitz Discussion 8 06-14-2006 11:17 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
