Old 09-20-2007, 08:56 AM   #11
Joker
the less backpressure the better on any engine. scc did a test years ago about all the aftermarket headers for hondas and none of them made any more whp than no header at all. all thru the rpm band, the no-header run made the most horsepower and torque.
(i'll see if i can find the mag somewhere...)
Less backpressure is better, NONE is not...by putting 2 1/2" pipe on any of our normally aspirated cars is overkill in every sense of the word. If you think your car is slow now go ahead and try it.....
To clarify I assume when you say "no header at all" you mean the engine was tested w/its stock exhaust manifold? The only other meaning would be the car had no exhaust manifold at all, esentially running the cylinder head "open" which makes no sense.
A header w/a good design should make some gains on our cars, when I say good design that doesnt mean the 4 into 1 DC header that recently came out. 4 into 1's are for higher (5000+ rpm) applications which means on the lower end your dead...unless of course you drive around at or near redline all day. Do some research, DC's own website highlights this fact!
Just trying to help out the inexperienced. Peace.....
T
Joker is offline
