Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Well said, steved. Also, hissing is not pinging. A ping sounds like someone striking an anvil with a ball peen hammer. If you hear a lot of pings in a row it can sound like an unbalanced washing machine in a spin cycle.
Hissing usually indicates intake air and exhaust gas movement. I've heard the 1NZ-FE engine produce a hiss under WOT (wide open throttle) in a high load scenario, which is just air moving into and throughout the throttle body.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
| DIY- rattle from lower windshield fix. | PetersRedYaris | DIY / Maintenance / Service | 3 | 08-21-2011 12:29 AM |
| Dash rattle TSB needed ! | tsportman | DIY / Maintenance / Service | 15 | 07-06-2009 06:20 PM |
| Rattle in head liner | gonzo452001 | DIY / Maintenance / Service | 8 | 09-08-2007 02:25 AM |
| Front Wheel Bearing Failure | craigq | DIY / Maintenance / Service | 4 | 08-17-2007 07:26 AM |
| Rattle fixed! | Bretsuaz | DIY / Maintenance / Service | 32 | 03-30-2007 08:39 PM |
