Old 07-09-2013, 07:04 AM   #1
kropekoi
Drives: vios 1.3J
middle logo
sorry if I am not reading the whole thread however, do we have any pics on how to remove the front and back toyota logo in the middle? I have a yaris sedan and I would like to know on how to remove them as I am planning on painting them black!
Thanks!
kropekoi is offline   Reply With Quote
Old 10-24-2010, 10:10 PM   #2
Tylermayer
Tylermayer's Avatar
Drives: 2007 Toyota Yaris
heres mines
Tylermayer is offline   Reply With Quote
Old 02-05-2011, 03:56 PM   #3
suprajoey
Drives: 08' Yaris
Originally Posted by Tylermayer View Post
heres mines
Wow, thats really clean looking.
Great thread and Good looking cars..!!
suprajoey is offline   Reply With Quote
Old 11-16-2010, 11:22 PM   #4
.Kevin.
I ain't even mad
.Kevin.'s Avatar
How exactly do you securely put these back on? Like I haveo ne double sided tape but it blows ass I got it at Canadian tire
Old 12-06-2010, 12:55 PM   #5
Yaris5
Drives: 2007 STI 2010 Yaris
Hey I have a 2010 yaris Hatch and I cant get the front emblem off for anything?
can anybody tell me how its attached or where to find the release pins to remove it?
also if anyone know where I can buy a replacement front emblem that'll be great also
thxs
casborne@hotmail.com
Yaris5 is offline   Reply With Quote
Old 12-06-2010, 12:57 PM   #6
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
thxs
I just stuck my pinky fingers into the grill at about the 4 o'clock and 8 o'clock positions (I think the two grill holes at the very edges of my avatar pic I took of my emblem) and curled them around until I felt the push tabs holding it on and pushed them in towards the center of the emblem and it popped right off.
Old 06-26-2011, 08:50 PM   #7
MitchReeves2967
Drives: 2010 Toyota Yaris Sedan
I literally just used a putty knife and the back emblems came right off. Then after painting put them back on with Double sided tape. I also painted the chrome trim on the trunk.
MitchReeves2967 is offline   Reply With Quote
Old 07-10-2011, 07:15 AM   #8
eric_edge
Drives: '11 3dr white
luvit
eric_edge is offline   Reply With Quote
Old 08-17-2011, 04:04 AM   #9
Red Raider
Red Raider's Avatar
Drives: 08 Yaris 3DR
wish i read more rather than being impulsive and scratching the sticky debris with a card...not to noticeable from more than about 2 feet away... any solutions?
Red Raider is offline   Reply With Quote
Old 08-17-2011, 05:28 AM   #10
nightstalker
Drives: 08 yaris lb
I used warm soapy water to get the rest of the debri off
nightstalker is offline   Reply With Quote
Old 09-07-2011, 06:35 PM   #11
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Red Raider: I'd think you may be able to buff it out. Looks minimal. Might have to wetsand but I doubt it.
NZ-FE Vios is offline   Reply With Quote
Old 09-15-2011, 03:23 PM   #12
henrylee
henrylee's Avatar
Drives: 2011 Yaris Sedan Red Power pkg
Been thinking of doing this mod. But im partial to the yaris emblem. Might just take the toyota off.
henrylee is offline   Reply With Quote
Old 09-15-2011, 03:26 PM   #13
NZ-FE Vios
Only Timing Chains
Turn the Yaris emblem into a bling chain.
Old 09-15-2011, 03:27 PM   #14
henrylee
henrylee's Avatar
Old 09-16-2011, 01:33 AM   #15
beebosaur
Drives: 2011 Super White 5 door hatch
Anyone know where I can get the 3m body tape? I wanna do this this weekend but can't find it...
beebosaur is offline   Reply With Quote
Old 09-17-2011, 03:17 PM   #16
roneezy360
roneezy360's Avatar
Drives: Toyota Yaris 2007
You should be able to find it at your local Wal-Mart. Thats where i found mine.
roneezy360 is offline   Reply With Quote
Old 11-25-2011, 12:34 AM   #17
Sam8madness
Drives: 2007 Toyota yaris hatch
thought I might toss in some info
I work at a body shop, and have to do this kind of work all the time.
If you are going with simple satin/flat black, just use trim paint.
it's designed for this exact application, requires only 600 grit sanding (or a scotch brite) clean with alcohol based solution and spray. No adhesion promoter, no primer or clear. Has full UV protection and holds up much better then your run of the mill plastic paint.
http://www.outdoorpros.com/Prod/Kryl...fhu=3733323832
Works great on rims too!
To remove emblems fishing line works the best
to remove the leftover tape a eraser disc works amazing, if that's out of the budget just roll it off with your finger and use some adhesive remover. Goo gone does effect clear, maybe not enough to notice, but it does effect it.
Hope this helps some!
Sam8madness is offline   Reply With Quote
Old 09-02-2013, 12:34 AM   #18
chanthasriro
Drives: Yaris RS 2013
i want part number front emblem.for yaris rs thailand.
chanthasriro is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
