Old 10-20-2008, 11:43 AM   #1
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Vacuum Gauge vs. MPG
I am surprised that no one has installed a vacuum gauge to determine the best shift points and driving style for all of your MPG guys!
I have one in my car (well a boost gauge - both vacuum and boost) and you can really notice a difference in gas mileage when driving the car so that you keep your vacuum numbers nice and high. Infact i found coasting in neutral burns more fuel then when the engine is under load. because under load i pull more vacuum psi.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 10-20-2008, 12:24 PM   #2
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
It depends on how fast you go when you coast. I regularly see 250 mpg at 50 mph on a Scangage when coasting a downhill grade on my regular route to work. I never see figures that high (except for DFCO) just by backing off the gas (for high vacuum).
Having said that, I have installed a vacuum gage in several vehicles I've had in the past and liked them. I always felt crippled whenever I had to drive a car without the gage, especially a stick shift.
Reddog99 is offline   Reply With Quote
Old 10-23-2008, 12:00 AM   #3
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
pix?
Old 10-28-2008, 12:22 PM   #4
natethegreat38
Party like a Barack star
natethegreat38's Avatar
Drives: '08 LB MT
I'm doing really well with my Kiwi (and without a vacuum gauge). My last tank of gas yielded 40.2 MPG... not too shabby!
i don't feel like creating another signature, yet. Give it another week...
natethegreat38 is offline   Reply With Quote
Old 10-28-2008, 08:42 PM   #5
briman
Drives: 2008 Toyota Yaris, automatic
Dumb question, but
when does DFCO kick in? I thought it was every time you coasted.
briman is offline   Reply With Quote
Old 10-28-2008, 08:55 PM   #6
natethegreat38
Drives: '08 LB MT
Originally Posted by briman View Post
Dumb question, but
From what I understand it is anytime you let off of the accelerator above 1100 RPM. Here's a good, easy read:
http://www.yarisworld.com/forums/showthread.php?t=4248
Old 10-28-2008, 10:21 PM   #7
Sodium Duck
╚══════════RN
So I guess we'll never see pics of this vacuum gauge...
Old 10-29-2008, 03:31 AM   #8
GeneW
Drives: 2008 Yaris
I'm skeptical about vacuum gages on a car that uses computer controlled mixture and both spark and valve timing.
As a rough and ready estimate of efficiency measuring manifold vacuum might be fine but for real in depth work you need to measure gasoline consumed per mile based upon how you drive.
Gene
Old 10-29-2008, 10:20 AM   #9
natethegreat38
Drives: '08 LB MT
+1
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Am I calculating MPG correctly? YarisBlazer General Yaris / Vitz Discussion 24 08-18-2007 12:57 PM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 11:41 AM
Wow, I Got 48.57 mpg Kaotic Lazagna General Yaris / Vitz Discussion 52 05-10-2007 11:09 PM
Yaris Mpg query Vanguard General Yaris / Vitz Discussion 3 03-18-2007 10:56 AM
