Old 11-02-2008, 09:37 AM   #37
kimona
kimona's Avatar
Drives: 2014 White VITZ
You need to clean the muffler first. Then, use heat paint specifically designed for that purpose. Your local auto parts store should have it, and I believe I saw some in Home Depot the other day.
The tip available at Walmart doesn't look like some cheapy crap. It's stainless steel and resonated, and actually looks very good!
Old 11-02-2008, 05:06 PM   #38
IsLNdbOi
IsLNdbOi's Avatar
Is there a DIY for removing the muffler?
Old 11-02-2008, 05:15 PM   #39
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
theres no need to remove muffler, but if you want to it is only a matter of undoing ,
the bolts with springs on them , (the ones above the axle).
as for paint just tell them you are painting excaust tail,
hope this helps .
Old 11-02-2008, 05:21 PM   #40
IsLNdbOi
IsLNdbOi's Avatar
Is this heat paint a spray paint? So it's safe to just spray paint the muffler w/o removing it?
Old 11-02-2008, 05:44 PM   #41
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Remove the muffler don't half ass it (it takes like 5 minutes) Just get spray paint with ceramic in it. Go to any auto parts store and find black spray paint designed for engine blocks or brake calipers. Either will work fine.
Old 11-02-2008, 08:36 PM   #42
kimona
kimona's Avatar
http://www.duplicolor.com/products/engine.html
Old 11-05-2008, 04:15 AM   #43
IsLNdbOi
IsLNdbOi's Avatar
Stopped by Wal-Mart and saw this $12 tip you guys mentioned. Looked pretty good, but it was too big, long and kinda heavy for my taste.
So, I went to Pep Boys and found another tip by the same company (Pilot Motorsports). The Wal-Mart tip is around 8.5" long and has a round, slanted tip. The one I got from Pep Boys is only 7" long and has a square, slanted tip. This tip cost around $27 though.
I have installed it already, but it was dark after I installed it so I'll post pics. of it installed later today when the sun is up. The slanted tip follows the rear bumper's curve nicely. I like this tip much better than that Valor / Toyota brand tip I got from my dealer for my '07 LB.
Old 11-05-2008, 09:41 AM   #44
kimona
kimona's Avatar
The Walmart tips are also by Pilot Motorsports. At 8 1/2", the round slanted tip is certainly not too long. Fit it tightly up against the muffler bracket and tighten. It will sit under the edge of the bumper by almost 2".
Old 11-05-2008, 07:28 PM   #45
IsLNdbOi
IsLNdbOi's Avatar
Here it is on my Yaris:
It doesn't stick out at all. The entire tip is still under the bumper.
Old 11-19-2008, 08:37 AM   #46
custom Lftback
custom Lftback's Avatar
There used to be a good thread on tips, and this was considered one of the favourites:
You can actually get it at Walmart for about $10. It's all stainless steel, resonated, and super easy to install. It fits the YarisHB perfectly without any modification, and it stays in place securely. I've had one on my car for more than 2 years.
http://www.jcwhitney.com/autoparts/I...D:100000186093
I went by wal-mart yesterday and found this tip, and I bought for $10 just like you said. lol. I put it on no problem and it looks great! Thanks kimona
Old 11-19-2008, 12:12 PM   #47
Revsson
I hate Wal-Mart, but that does look like a nice tip.
Most of their things are from China. Where is this tip made?
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
Exhaust tips Sedan Liftback tomjasz Cosmetic Modifications (Exterior/Interior) 25 08-14-2006 06:05 PM
