Old 12-04-2008, 08:33 PM   #1
at3GG
at3GG's Avatar
Drives: 07 metmet LB
so wait...his intake assembly is going to be behind the engine then?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 12-06-2008, 09:42 AM   #2
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
I guess, the turbo need to be very close in the exhaust piping, just above the oil level for oil drainback, so the air intake need to bring fresh unrestricted air there, pressurized and sent out front for cooling, back to the throttle body.
As far as fuel management, I just don't see how not to upset the computer, piggyback is a hell of a headache and not cheap, the adaptation of the ECU will mess the tune in a matter of hours, it need a complete reflash, or to run a standalone in conjunction with the present computer to run the acceesories, but the EMS will still be pissed off...
The only ways I see to do this from now is either to run a 5000 $ Motec EMS or revert to cable throttle, hacksawing the whole throttle system and revert to pre historic engine control.
To run a piggyback:
EGO :
we need to lie to the EMS, we need to control, O2 sensors signal so the ECU thinks that it's running right not detecting the over rich condition or it will trim the fuel gradually until maxed out, then will trigger limp mode
MAF :
Limit the MAF signal so the EMS don't detect overboost and trigger limp home maps, the ECU need to think he's running WOT
Relying on a MAF signal mod will mess the timing tables, so the engine need to run as stock below 0 PSI
Injectors :
Intercept the injector signal modifying it to run larger injectors, the piggyback need to read Manifold pressure and compute pulse width
Ignition :
Intercept the CPS signal and offset the signal as boost retard (6 PSI+), still the engine may see that the crank is not phased with the cams sensors and trigger a CEL and limp mode, if below 6 PSI leave timing in full advance, use higher octane fuels instead.
I'm sure that if I think of it some more I will find even more stuff and the ECU will fight back any abnormalities, it may even datalog and blow the warranty, if someone care :D
Edit : I told you I'll find something else lol, the EMS may be able to compute that the TPS and MAF signal are out of wack and trigger limp mode again.
Testing testing testing...
gboezio is offline   Reply With Quote
Old 12-06-2008, 12:49 PM   #3
poor little guy :(
The driver? LOL
Old 12-06-2008, 11:53 PM   #4
heeroyuy01195
Post count means nothing.
The driver? LOL
I'll leave that for you guys to decide
Old 12-07-2008, 06:47 PM   #5
at3GG
at3GG's Avatar
anyone know the measurments of this IC? whats the max our engine bay will allow without serious cutting?
Tanabe Df210's
Old 12-07-2008, 07:36 PM   #6
measure your lower grill
Old 12-07-2008, 07:39 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
lol making me laugh on a sunday.....
Old 12-07-2008, 08:32 PM   #8
glad to be of service, Mr Tamago.
Sincerely,
Mr. Obvious
Old 12-07-2008, 08:33 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
Sincerely,
Mr. Obvious
i fabbed mounting brackets on an intercooler for a 300+whp mazda 323 today.. needless to say, he didn't measure his lower grille before he bought the IC..
but who cares.. that car GOES!
Old 12-08-2008, 07:29 PM   #10
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Geez, I bet!! Is it the GTX model? That's my fave. Rally-x!!!!
anonymous user is offline   Reply With Quote
Old 12-07-2008, 08:47 PM   #11
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
lol and please don't buy a super huge IC thinking you will gain more, im using one that is around 12x10
Old 12-07-2008, 08:59 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
my IC is tiny and never overheats.. small cars + small turbo need short IC piping and properly sized IC.
Old 12-07-2008, 10:19 PM   #13
+1 !
Old 12-08-2008, 07:04 PM   #14
at3GG
at3GG's Avatar
ok thanks thats all i was trying to figure out.
Tanabe Df210's
Old 12-08-2008, 10:39 PM   #15
Nexus1155
Drives: Audi
http://members.optusnet.com.au/loxy/...cooler/bov.jpg
You tell me! ;) We'll play a little hidden object game
Old 12-08-2008, 11:19 PM   #16
pinoypizzaboy
Drives: 08 toyota yaris LB
hmm so its bolted to the intake tubing?
pinoypizzaboy is offline   Reply With Quote
Old 12-12-2008, 07:08 AM   #17
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Exactly. Blow off valves really do not have much of a performance advantage unless you're running really high horsepower and high boost. Most people install them on their turbo kits because they make such a cool sound
Old 12-08-2008, 10:51 PM   #18
Treyz
~ ambient one ~
Treyz's Avatar
So is this another project gone MIA?
WE NEED UPDATES CDYDJDED!!!
Then again, it's been a month since the thread was created again from the hack.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Under $2500 Tubo Kit Update 2 cdydjded Forced Induction Forum 72 11-02-2008 09:44 PM
$2500 Turbo Kit is back to life! bdc87 Forced Induction Forum 8 10-20-2008 09:46 AM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
Under $2500 Tubo Kit Update cdydjded Forced Induction Forum 16 08-26-2007 11:05 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 04:51 PM
