#37 | |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
I agree , flirting with disaster ,
#38 |
Need to sell my Yaris :(
Drives: 07 Yaris S Join Date: Nov 2008
Yes it is, BUT N2 won't drop in pressure as fast as regular air, the tire pressure should stay more consistant due to there being no moisture in the N2 (with regular air you should check your pressures atleast once a month, with N2 you can go 3 to 4 before checking the pressure) AND is supposedly going to give you slightly better gas mileage as well (not completely noticable but its been told). I work in a tire and automotive shop so I work with this kind of thing all day 6 days a week. Most tire shops are starting to offer the N2 service now. Where I work its $2 per tire and then free after that. If you notice that your tires are low and you have N2 in the tires its perfectly fine to put regular air in them just when you can go back to where you got it installed and have them purge and refill with fresh N2 as the regular air will have diluted it.
ALSO on the inside panel of your driverside door read the placard, it will tell you the correct pressure that the manufacturer calls for in the tires DONT go off of what the tire says.... You could be over inflating your tires and that could cause uneven tire wear and possible hazards. (Wow I feel like I am at work lol) |
#39 | |
#40 |
I'm not trying to argue with you Voodoo, but we do work with this everyday and we see the effects of how people mistreat their tires, you may be an exception bc you haven't had anything happen to you yet, but just be aware that it is possible. We (natethegreat and I) are only giving you what we know and see and highly recommend that you stick to the manufacturers recommendations seeing as they do extensive testing as well as the tire companies to determine what certain vehicles and tires can handle in order to be safe for you and others around you.
#41 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I find it most ironic that folks on this forum can talk about replacing the steering wheel with one that doesn't have an airbag and no one bats an eyelash, or dropping the car so low that it can't turn properly or negotiate speed bumps and everyone cheers them on, or supercharging an engine that was never designed for it and everyone gathers round the campfire to tell stories, but the minute anyone brings up raising tire pressures people begin to preach in the supposed name of safety.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#42 | |
Audio Junky
#43 | ||
Party like a Barack star
Drives: '08 LB MT Join Date: Oct 2008
i don't feel like creating another signature, yet. Give it another week... |
#44 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
What I also think is being left out here, is that it is proven under inflating your tires is unquestionably dangerous. This is what really causes blow outs and hydroplaning. It also causes a large decrease in FE and tire life. Even if you don't prescribe to the philosophy that inflating to the max sidewall and even a little beyond is not going to cause you problems unless you are driving your car incorrectly to begin with and then you're a hazard on the road no matter what the psi is in your tires. I would at least hope everyone would stress that everyone should never under any circumstance have a psi lower than the one listed in their cars manual. For me the bottom line is to never take anyones word on anything. Research it and figure it out for yourself. If you take someones word simply based on how much money and research they say they spent on something or how big of a company they are then we'd still believe things like the world is flat and that the Ford Pinto was a safe car. |
#45 | |
#46 |
I'm over it. You can only explain something so many times... whether or not one wishes to listen is up to them. Thanks to those who understand. I'll properly inflate my tires and live happily (and safely) ever after.
#47 | |
Audio Junky
#48 | |
#49 |
![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
I’ve been lurking on this thread for a while…
I think talnlnky is saying different appreciation requires different psi with the same tire. It needs more psi if the vehicle weights more to keep the tire’s form/shape intact to hold the road and weight. I could be wrong. I will crawl back underneath my rock now. |
#50 |
![]() ![]() ![]() Drives: '09 Yaris 3dr, 13 F150rcsb 5.0 Join Date: Oct 2008
#51 | |
Audio Junky
#52 |
We have had a few days of storms that have dropped lots of rain and about 5 inches of snow at altitude. 17 of the 27 miles of my commute was under snow tires or chains controls today. On the way to work I and my two carpoolers saw two 4x4 pickup trucks that had lost control and gone far enough off the road to require winching. On the way home we saw another 4WD vehicle in the same position.
We traversed the mountain in both directions without issue. At 60 PSI.
#53 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
I'm just curious as to what effect this kind of stuff has on the car. I would think personally as seeing certain brands of tires undergoing 120-150 or more psi while trying to seat the beads 60 psi is nothing....I can only see a problem with "over-inflation" if high speed was involved and the over-inflation was not performed prior to balancing the wheel/tire set....as out of round issues would appear. I'm wanting to understand the reasoning and logic behind this instead of persecute and judge. |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 06:40 PM |
| $7 Ram air intake pictorial | turbodiesel | Performance Modifications | 19 | 10-27-2008 05:46 PM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 01:23 AM |
