Old 11-19-2008, 08:38 PM   #1
stran
Drives: '07 Yaris 3D HB Auto
Save gas by not running A/C with defrost
http://www.yarisworld.com/forums/showthread.php?t=10888
stran is offline   Reply With Quote
Old 11-20-2008, 05:59 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I'm a worse than all thumbs type,a pictorial walkthrough would really be helpful.
Old 11-20-2008, 08:21 AM   #3
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Originally Posted by stran View Post
*i meant "by" not "but" but i can't edit the title*
Yes, you can edit a title. After you hit the EDIT button then hit GO ADVANCED and you will have the optiion of editing the title.
Old 11-20-2008, 08:57 AM   #4
i fixed it
Old 11-20-2008, 11:57 AM   #5
stran
thanks
Old 11-20-2008, 12:01 PM   #6
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
dry air is what makes defrost work....
why take out the AC?
Old 11-20-2008, 12:11 PM   #7
stran
So can you control when to run A/C instead of running it all the time. Here's what I do when it's cold at night (and hence near the dew point which means things fog easily) or when it's raining:
To prevent fog from forming - defogger mode with cold air. I also do this when I start my car. By not having the A/C on, it's not as cold in the cabin and I don't need to poach heat from the engine so it warms up faster. Cold engine = bad bad gas mileage.
A little fog - defogger mode with warm/hot air. No A/C = no compressor = half the gas consumption at idling (according to SG II).
Heavy fog - haven't had time to see if I even need to run A/C to clear the windshield, but if needed, I will run it in spurts instead of running it all the time.
Also, running the rear defogger has almost no impact on gas consumption - it uses less gas than turning on the headlamps.
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 05:31 PM
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 05:20 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
