Old 11-25-2008, 10:05 PM   #9
SilverGlow
Drives: 2007 Yaris Hatchback
Use the synthetic that's on sale. Either one will allow your engine to last through 300,000+ miles. In addition, it is a waste of $$ to not extend your oil changes if you go with synthetic. However if your car is still under warranty, I would not go more then what the manual states. After the car is out of warranty, then go with synthetic and the oil should be good for at least 7,000 to 10,000 miles, depending on how you drive, where you drive, and the brand of oil.
At the end of the day, you can put the "worse" synthetic oil in your car, and it will still pull strong at 300,000+ miles...this is something no one really wants to admit because for most, oil is "religion" and their preferences are more found in very subjective reasons, devoid of scientific back up. ;-)
Before you change out a particular brand, do a UOA and use that as a base line when trying other oils, or you could just get what's on sale and call it a day.
SilverGlow is offline
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Royal Purple FTW Nibs DIY / Maintenance / Service 11 09-28-2007 01:06 PM
Mobil 1 versus Royal Purple caveatipse DIY / Maintenance / Service 6 09-08-2007 08:54 PM
Anyone familar with Royal Purple synthetic oil? Yaris_Fan DIY / Maintenance / Service 34 06-23-2007 12:29 AM
Yellow, Purple, Green Headlight BULBS? jamal1984 Cosmetic Modifications (Exterior/Interior) 12 02-04-2007 08:30 AM
