Old 12-12-2008, 11:04 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Problems?
Okay, so i bought my 2009 Toyota Yaris at the end of October of this year. So i've had it for like, 2 months.
The brakes have become very mushy, to the point where i have to forcefully push them as far as they can go to stop the vehicle at any given speed.
One morning I was doing around 25 mph, and the car just wouldnt go any more, so i pressed the pedal down far, and nothing happened..so i pulled over..just checked things out, and it was fine after that.
So I take it back to toyota, I have them check it all and everything, and they stood there and called me crazy and said nothing was wrong with the vehicle.
Has these problems happened to anyone else?
And also, does anyone have problems with the automatics not shifting after 40 mph?
Twistoffate0817 is offline   Reply With Quote
Old 12-13-2008, 12:31 AM   #2
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Okay, it sounds like you have a lemon. Drive it to another Toyota dealer to have it checked out. They can't be the only Toyota dealer in your area.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 12-13-2008, 12:34 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
sounds like you are accidentally placing the car in 3 instead of D when you come out of the neutral you should make sure the selector moves over to the right.
PLEASE CHECK OUT THIS SIMILAR THREAD!!! <<<<CLICK
Old 12-13-2008, 01:24 AM   #4
ddongbap
That doesn't really solve his problem.
Old 12-13-2008, 10:31 AM   #5
b_hickman11
Drives: 08 Sedan
It will solve his "not shifting after 40 mph" problem. As far as the brakes go be sure the check the fluid level. I would also go back to the dealer and ask them to bleed the brakes for me.
Old 12-13-2008, 12:30 PM   #6
500snakz
500snakz's Avatar
Drives: 08 Polar white hatch
It is because you did not let it warm up upon starting it. The "cool temp light" on the dash must go off before driving. It will not shift properly and stays in 3rd gear. I think it is a MAJOR safety issue and am probably going to get rid of my yaris for this issue.
Another STUPID idea from toyota...
500snakz is offline   Reply With Quote
Old 12-13-2008, 12:53 PM   #7
voodoo22
Drives: Yaris Sedan (auto)
This "stupid" idea lowers your maintenance costs long term. I fail to see how in anyway this could be construed to be a safety issue of any kind. A major safety issue in my opinion is something like the fuel tank in the Ford Pinto. Not an feature which forces the engine to be warm before shifting like it would under optimal temperatures.
It's also better to drive the car slowly as soon as you start it versus idling. Better for fuel efficiency and better for the maintenance of your car.
Seems like you hate a lot of things about your Yaris. I suggest you research and test something better before you buy it next time. Sure, the Yaris is far from perfect and some things about it annoy me (The warm up feature which prevents proper shifting until a proper engine temp is reach, included), but the Yaris is a great car for what it was intended to do.
voodoo22 is offline   Reply With Quote
Old 12-13-2008, 02:06 PM   #8
1stToyota
1stToyota's Avatar
My dealership took care of that "safety issue" for me; they sold me a 5-speed.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-13-2008, 06:56 PM   #9
bronsin
bronsin's Avatar
Once I had the floormat interfere with the brake pedal. Barely stopped for a stop sign.
Old 12-13-2008, 07:10 PM   #10
b_hickman11
Drives: 08 Sedan
ALL cars have this same "issue" as you call it. All cars(AT) must warm up properly before they will shift correctly. Toyota has given you a light to know when the warm up period is over and you can drive it normally. Stupid idea? So it's stupid for them to let the driver know when its "safe" to drive normally as oppose to other cars that you have to "guess" when the car is warmed up. Also, my dealer told me that it was better for the life of the car to drive it carefully during the warm up period instead of letting it idle to warm up.
Old 12-13-2008, 07:18 PM   #11
ddongbap
So you know the problem, and you also know the solution. Yet you still call out Toyota on this, and I'm going to assume you ignore the light and drive anyways.
Old 12-13-2008, 07:30 PM   #12
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Everyone must be really stressed out from christmas shopping or something, it's like a 24/7 whine-fest, pitty party, bash-o-rama around here lately.
Old 12-13-2008, 07:59 PM   #13
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
The warming thing with the auto is for emissions reasons. When your car is cold it emits worse fumes than warmed up. So the tranny doesn't up shift into the overdrive gears until it reaches a certain temp. It helps the engine warm up faster. With my ECHO i Have this. Its annoying but oh well, as long as the car starts and keeps going I can't complain.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 12-13-2008, 08:52 PM   #14
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
Thanks! solved my problem!
msfire671 is offline   Reply With Quote
Old 12-13-2008, 10:57 PM   #15
ddongbap
IDK about everyone else, but I'm 100% of the year whine-bash-flame fest.
Old 12-16-2008, 08:50 AM   #16
500snakz
500snakz's Avatar
Ok lets see...Car cool temp light is still on after warming a few minutes or you drove off slowly to let it warm...OH CRAP there's a car that I must avoid hitting me in the rear because I driving slow on the highway. I mash the gas pedal and nothing but over tached motor and no shifting...going 40 mph tops...SMASH!!!you just died because your car was in cool temp mode...DO YOU SEE NOW? or should I elaborate more? I think it's a stupid idea and have never had another vehicle of any kind do that. And I have had quite a few cars, trucks, and suv's. I have been driving for 26 years and that is longer than most of you have even been alive. Unlike a lot of members here, the yaris is NOT my first car.
I have my opinion and you have yours. I don't like that you and others flame me because I don't live in your "Toyota is God world". I like my yaris very much BUT it is NOT the best thing since sliced bread. It does what I bought it to do...save gas and be reasonably dependable and low cost of ownership, PERIOD...So stop your flaming and whining and understand that not everything is perfect with this car...
Old 12-16-2008, 09:40 AM   #17
1stToyota
1stToyota's Avatar
SHWING!!! Mine has a 5-speed...and so did my Escort GT...and my Contour SVT...oh dang it!!!! Guess what? STILL got rear-ended in both of those cars while minding my own business. Was hurt pretty seriously in the Escort and did $8K damage to the rear...estimates are that the guy was going about 90mph. Wouldn't have mattered if it was winter or summer, stick or auto, there are some accidents that just can't be avoided when the other guy is driving wreckless and about twice as fast..
2008 Scion xD
Old 12-16-2008, 09:52 AM   #18
500snakz
500snakz's Avatar
That is true for sure. BUT can you see my side of this also? If you can't get out of the way it does increase your odds of getting rear ended.
HELP WITH NEW 2007 PROBLEMS partenac General Yaris / Vitz Discussion 15 05-31-2007 05:06 PM
some minor problems after installing my HID kit, any professionals? ASHRAF DIY / Maintenance / Service 14 03-09-2007 10:54 AM
headlight problems KSIbucky DIY / Maintenance / Service 2 02-28-2007 10:54 PM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 11:50 AM
major problems? kaymm General Yaris / Vitz Discussion 3 09-18-2006 08:25 AM
