#1 | |
![]() ![]() Drives: Yaris RUSH HatchBack Join Date: Jan 2009
hi there, may i know where can i find this stuff? regards, Charles |
#3 | |
so did ya mean it is located under the driver seat or passenger seat? because my driver seat is on right hand side. regards, Charles. |
#4 | |
Hihi, I already tested the wires tat u mentioned in the picture.. The blue wire does give constant 12v and the pink wire should turn on the lights with the door right? I already tested the pink wire by multimeter and it will only give 12v when the door is closed. So may I know what can I do in order to get 12v out when the door is open because I want my led to be on only when the door is open... Thanks... Last edited by charleschia1986; 11-24-2009 at 01:53 AM. |
#5 | |
thanks a lot...
i tried and it WORKS..... thank scott |
#7 | |
Hi to all... just a noob here in M.E., just wondering if I tap the leads (+,-) of an LED light to the pink n blue from that pic above, will the new led light acts the same as the dome light? will the new led light dim to off as well upon turning off the ignition? Or just turns on when the doors were open? Sorry to much question. Need help where I can tap my led lights so that it behaves the same like the dome light, using its switch also to turn on my led lights underneath. Thanks so much. -jon
#8 | |
#9 | |
![]() Drives: Vios E Join Date: Mar 2011
Hi, how do you suggest wiring LEDs so that they behave exactly like the dome light does? ie. turn on when doors open, switch to ON - light up with dome light. thanks
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Alright, so if I'm thinking correctly I should connect the + lead from the lights to the blue wire, and the ground to the pink one?
![]() Drives: Beautiful :) Join Date: Jun 2009
Use the clip things (tap splices). Just sticking the wire in along side of the existing wire does not make a reliable connection.
Awesome, thanks!
![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
So the yellow 12volt wire described in the first post is constant even when the car is off?
Yes
![]() Drives: yaris 1.0 vvt-i Join Date: Oct 2008
Hello! I have an alarm to put on my Yaris (from 2002). Where i can find a diagram of the car with that?
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
