![]() ![]() Drives: Yaris RUSH HatchBack Join Date: Jan 2009
thanks CTscott for ya Helpsssss,
here is the link of my Final product. u may have a look. http://www.yarisworld.com/forums/showthread.php?t=24210 Last edited by charleschia1986; 12-06-2009 at 10:26 PM. |
やりすぎだ~
Hi all. Is there a place I can tap into the engine bay for turn signals besides the wires that lead to the signal lamps?
#3 | |
Conn B13.jpg |
やりすぎだ~
One more question, where can I tap in for the parking lights - the lights that go on just before I turn on the headlights?
やりすぎだ~
Sorry, should've made my question a bit clearer. I'm looking to see if there is one in the fuse box like the one pictured above.
In the fuse panel, it is pin 3 on Connector B13, which is the green wire next to the two red wires in my picture above. If you don't have fogs installed, the place where the two reds are in my picture will be empty on yours.
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
I just want to take a minute to say a big, fat THANK YOU to ctscott for his help on these boards.
I have used a lot of your info and I believe you deserve at least this much appreciation! Thanks, brother! |
![]() Drives: Yaris Liftback Join Date: Dec 2008
it tried tapping the light blue wire at the headlight switch, but now my headlight wont turn off and the lights on my power window switches are on all the time?
did i just do a bad job tapping this? or can i not tap the light blue wire for my power window switches? thanks, nick |
the power window switches i got light up at night when the headlights are on
#12 | |
Secondly, you don't want to use a high current circuit, like the headlight switch, to drive interior lighting. You want to use the illumination circuit, which you can access either at the shift lever or at the dimmer rheostat. At the shift lever, there is a two pin connector with a white and a green wire. Green is +12, white is ground. At the dimmer rheostat, there is a 10 pin connector. The sky blue wire is +12 and the light green is the headlight switched ground. |
^^ awesome thanks so much for the info!!!
So i tried the sky-blue wire at the dimmer and it works. However its dimming the power window switches in the opposite direction as the dash. So when the dash is fully lit, the power window switches are not lit at all and vice-versa.
I checked the connection with my multi-meter and it is indeed +12V so im not sure whats wrong. My car is MT so there is no shift lever, is there another headlight source i can tap? Thanks for the help! Last edited by nmd55; 10-26-2010 at 10:42 PM. |
#15 | |
as it turns out i was tapping the LG wire the whole time thats why it was dimming in the opposite direction. However the SB wire is an ignition switched 12V, so tapping that doesnt work either because the switches are on all the time with the SB wire.
I think i am going to have to find another source to tap. Last edited by nmd55; 10-27-2010 at 12:41 AM. |
#17 | |
I just realized that I gave you the wrong wire for the +. Use the brown on the dimmer rheostat, not the blue. |
![]() ![]() Drives: 07 Yaris Join Date: Mar 2007
I put an aftermarket stereo in my 07 hatch but I couldn't find the dimmer wire.
The stereo has this feature. This blue light is almost blinding at night. Is there a dimmer wire in the stereo bundle? |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
