#73 | |
Secondly, you don't want to use a high current circuit, like the headlight switch, to drive interior lighting. You want to use the illumination circuit, which you can access either at the shift lever or at the dimmer rheostat. At the shift lever, there is a two pin connector with a white and a green wire. Green is +12, white is ground. At the dimmer rheostat, there is a 10 pin connector. The sky blue wire is +12 and the light green is the headlight switched ground. |
#74 |
![]() Drives: Yaris Liftback Join Date: Dec 2008
^^ awesome thanks so much for the info!!!
#75 |
So i tried the sky-blue wire at the dimmer and it works. However its dimming the power window switches in the opposite direction as the dash. So when the dash is fully lit, the power window switches are not lit at all and vice-versa.
I checked the connection with my multi-meter and it is indeed +12V so im not sure whats wrong. My car is MT so there is no shift lever, is there another headlight source i can tap? Thanks for the help! Last edited by nmd55; 10-26-2010 at 11:42 PM. |
#76 | |
#77 |
as it turns out i was tapping the LG wire the whole time thats why it was dimming in the opposite direction. However the SB wire is an ignition switched 12V, so tapping that doesnt work either because the switches are on all the time with the SB wire.
I think i am going to have to find another source to tap. Last edited by nmd55; 10-27-2010 at 01:41 AM. |
#78 | |
I just realized that I gave you the wrong wire for the +. Use the brown on the dimmer rheostat, not the blue. |
#79 |
![]() Drives: Vios E Join Date: Mar 2011
Hi, how do you suggest wiring LEDs so that they behave exactly like the dome light does? ie. turn on when doors open, switch to ON - light up with dome light. thanks
#80 |
The only way to make them function exactly the same as the dome, including the switched on mode is to run the power wire up through the headliner to the dome light and make your connection there.
#81 | |
Now I'm worried they might catch fire/melt/burn. What's your opinion on this? Should I get thicker gauge wires and redo the whole thing? Last edited by iicaie; 03-23-2011 at 12:41 PM. |
#82 | |
#83 | |
but they look pretty much the same. |
#84 |
Those wires are actually 20AWG. Your 26AWG is only rated for 2.2 Amps, so to be safe you should add a 2A inline fuse between it and your new lighting.
#85 |
![]() ![]() Drives: 07 Yaris Join Date: Mar 2007
I put an aftermarket stereo in my 07 hatch but I couldn't find the dimmer wire.
The stereo has this feature. This blue light is almost blinding at night. Is there a dimmer wire in the stereo bundle? |
#86 |
![]() Drives: yaris Join Date: Apr 2011
help pls
any one who knows where can i find main body ECU of yaris 2006 because ihave bypass module dball data base tranponder i need to connnect (stsw output to stsw+ pi4 of ECU main body , but idont no where? pls help any diagram regarding stsw wire yelow no 8 frm. dball http://www.xpresskit.com/VehicleComp...px?p=null&year to see chart of my problem,
#87 |
The main body ECU is actually the white box under the dash with the fuse panel mounted to the bottom of it.
#88 |
thnks i check it up later
#89 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Anyone know which of those wires is switched / ignition power? I tried the other red one, (the red one that's not labeled), but it's not working.
#90 |
The red one that's hidden on the end of the second row is definitely ignition switched +12 volts. Make sure you have a good ground that you are referencing it to, or use the white wire with the black stripe on that connector as your ground.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
