#55 |
I have gotten the same slight grinding going into 3rd when shifting fast. I have both NST SSK's, and have only experianced it at the track. Calming down a little bit has cured the problem
without a significant increase in shift times.
#56 | |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
R-CaT Project Yar 2ZR |
#57 | |
...funny, UPS shipped my ENEOS to me, in the ENEOS box, and about $3K worth of AMSOIL products to a friend of mine. I've decided to go with the AMSOIL GL-4. Should be here in a day or two.http://www.amsoil.com/StoreFront/ima..._qt_350pxh.jpg |
#58 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
bummer , was hoping to see how the PENNZOIL synthetic GL-4 would do for your tranny
. Let you and your car be the lab rat . Just kidding , sure it would've performed well . Let us know how the AMSOIL MTG works for you . THANKS
#59 | |
GL-4 powns GL-5
#60 |
that's good
. Enjoy
#61 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
I can't rave enough about the MT-90. I love shifting through the gears now.
#62 |
cold shifting is much easier in these temps .
#63 |
Reverse will get a good test tomorrow morning. The longer the GL-5 stayed in the transaxle the notchier the shifts were getting and finding reverse on the first try was starting to become a joke.
#64 |
yup , downshifting with GL-5 was a joke , would grind like crazy
. Work through all gears as much as possible and drive around in reverse in empty parking lot or back street / road ( people may think you're nuts ) . I leave car in reverse when parked . ENJOY |
#65 |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Two thumbs up, Redline MT-90
+1. Shifts better, better mileage. GL-5 has more extreme pressure additives for hypoid gears than can rob mileage.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
#66 |
Drives: Yaris Join Date: Jan 2009
MT-90 is a beautiful thing.
| Manual Yaris performance info? | SimmZ | General Yaris / Vitz Discussion | 22 | 10-27-2009 09:27 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| The Toyota Authorized Repair Manual. | LoudYar | General Yaris / Vitz Discussion | 3 | 03-29-2007 12:20 AM |
| 2007 LB Yaris - AT - Fluid Change Interval | Pavel Olavich | DIY / Maintenance / Service | 9 | 03-21-2007 06:09 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
