Old 01-24-2009, 05:57 PM   #11
CB900F2
Drives: 08 Sedan
A belt tension gauge should be used to check the tension on the belt and to insure it is with in spec...
Originally Posted by ztrack157 View Post
I have NST as well. And in the last 2,000 miles I heard a noise I knew shouldn't be coming from the engine bay. It was the water pump. I don't know what is considered to tight I can still wiggle the belt. And I had thought it was to tight so i loosened it slightly and then spun the belt so it wasn't to tight after installation.
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
