Old 01-24-2009, 06:12 PM   #11
SailDesign
Drives: .
Originally Posted by ddongbap View Post
Good point. Sorta. I see your point. But sidewall is going to flex as bad as w/e, with max psi, or lower psi.
Sidewall flex def drops with higher pressure. Take it to extremes, and look at a nearly-flat tire compared to a well-pumped tire. I realise this isn't totally fair, and that the difference between a HIGH-pressure tire and a normal-pessure tire is significantly less than the example.
But...
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 10:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
