Old 02-04-2009, 12:38 AM   #1
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
So I installed a set of fogs from kargoboy that I got from Long. I'm having trouble wiring up the switch for proper illumination. My understanding is that the fog lamp image on the switch should only light up when headlights/DRLs are turned on, and the LED should light up when the switch is pressed down. From the switch I have 2 pink wires that go into one, and a blue wire with a red stripe. There is also a ground. What do I do with the pink wire and blue/red wire? I also used the method of using the OEM toyota relay. Thanks!
cm07yaris is offline   Reply With Quote
Old 02-04-2009, 02:29 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Okay
The pink wire is power in ie take power from your park lights ,
there is 2 leds in the switch one will come on as soon as it gets power
the other lights as well when fogs are turned on .
The blue/red wire is power out signal
The black is earth
You can PM me your email i will send you the factory instructions
or you can spend another $70.-$80US and buy the factory Stalk with fog light
switch on it which will then take all this wiring away.
hope this helps
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 02:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 07:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 10:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 05:24 PM
