![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
I'm about to buy some wheels for the yaris.
16x7 +43mm offset. I know for a fact that +42mm rubs, and that +45mm does not rub. Do you think +43mm would rub? its only a millimeter more than the +42mm, but it might be just that millimeter that makes the difference? Don't ask me if the car is lowered or not, because that doesn't make a difference.. having a full car with passengers and stuff in the trunk is the same as lowering, or when you go over a bump or dip hard-enough the suspension will travel just as low. |
| What are you doing right now? | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 26819 | 12-31-2010 10:48 AM |
| want 2 lower with tein but have tyre rub HELP! | MR. CANTON | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-24-2007 04:16 PM |
| Got new wheels, tires, and springs installed. | largeorangefont | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 44 | 09-22-2007 04:21 AM |
