Old 02-24-2009, 08:01 PM   #19
metalshark
MetalShark
Drives: 2008 Yaris LB
I've been running K&Ns on the big V-8s for years. I clean them once a year and re-oil. On my truck its a whopping 14" diameter by 6" tall so I never have a measurable restriction even when its caked on. Typically these types of filters do a better job of cleaning the air after they are dirty up to a point. I've had the big trunicated cone type on a CAI inside the left front filter for one year now. Its been in there for 20,000 miles so its time.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline
Old 02-24-2009, 08:07 PM   #20
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
yeah and I like my TRD one witch I think is the same thing as a K&N right? Ever since I put it in I noticed a tad more umph! not much though
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline
Old 02-24-2009, 10:29 PM   #21
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
here's the umph curve
miniscule------------------------tad----------------------VTEC!! MMMMMMMMMBAAAAAAAAAAAHHHHH!!!!!
Originally Posted by xnamerxx
you nailed it sir.
Tamago is offline
Old 02-25-2009, 01:06 AM   #22
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
be careful with the oil,it can gunk up the MAF really quick and give you a CEL.
bzinn 1 is offline
Old 02-25-2009, 01:13 AM   #23
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Originally Posted by PetersRedYaris View Post
Keep paying for them? One kit last for multiple cleanings, which only need to be done every 50,000 miles for regular street driving...
+ 1...I have K&N's in my Sequoia, TSX and Yaris. I've made the cleaner kit last several years. I agree on being cautious with over-oiling.
In terms of performance gains, it's hard to tell. I do exceed the EPA mileage on all three cars.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline
Old 02-25-2009, 09:39 AM   #24
1stToyota
1stToyota's Avatar
And that intial 1hp at the wheels (until the PCM adjusts for the extra airflow that it now sees) that you think you're feeling because you're driving more aggressive to hear the extra noise being made under the hood can quickly turn into about a 20hp loss at the wheels when the MAF gets gunked enough to set a code.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
1stToyota is offline
Old 02-25-2009, 10:26 AM   #25
only way it gunks up the maf is if its waaay over oiled. i had k&n oiled filter on my xrs and never had a problem w/ an oiled maf even running to 8350rpm...
its a common misconception that an oiled filter with screw up your maf....its gross user error to have that happen...
as for the hp increase...im sure its almost negligible in the yaris....but the ecu doesnt compensate in the way youre describing, otherwise you would never feel any power increase for any mods done on a stock ecu...and thats just not the case.
how much are those stock paper filters? for me, id rather spend the $50 on 1 k&n and never have to spend money on cruddy, restrictive paper filters
thebarber is offline
Old 02-25-2009, 10:52 AM   #26
1stToyota
1stToyota's Avatar
HP gains come from real mods, followed by a dyno tune. Try putting a cam, heads and LTs on a LS-1 motor w/o a tune. You'll be lucky if you can back down the drive until it's tuned, and then you'll see 100 or so extra hp at the wheels. And the PCM works exactly like I said...the MAF measures AIRFLOW, that's why a car will still stay running even when the paper element can be completely clogged with dust, trash, dragonfly legs, bird feathers, etc...
And it kinda depends on the location of the MAF, if it's real close to the airbox better chance of catching non-100% air across its heated wires. I'd say it's not a misconception when TSBs are issued on oiled filters.
K&N (drop-ins) is great for saving money but not for HP gains, maybe 1 or 2 hp at the wheels of most applications, at best. Probably saw better gains back when they first came out and was installed in bigblocks with hi-rise manifolds and dbl-pumpers, but now cars are getting too smart for minor mods w/o reflashes.
2008 Scion xD
Old 02-25-2009, 11:13 AM   #27
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
The bottom line is simple to understand. As "thebarber" said, it doesn't take much to figure this out. WHY spend $ on cheap quality paper filters every couple months, if you can just get something that will less you a eternity for less then $50.00 bucks? Even IF you don't see any significant changes as some of you described previously, just the fact the you don't have to keep buying these filters over and over again, pays for itself.
Now, use your best judgement!
GioBatera
Giobatera is offline
Old 02-25-2009, 11:52 AM   #28
1stToyota
1stToyota's Avatar
It's no big deal
In a perfect world no one will ever over-oil their filter, and if they do they'll always be smart enough to clean the MAF and have a code reader to see the MAF code and not have to pay a mechanic to read the code and clean the meter at a pricely sum, if the mechanic doesn't decide to make a MAF sale instead of just cleaning it. 50$ investments can get quite expensive.
had to be a need
...and paper filters are good for 15k miles, a year or more for most, not every 2 months
2008 Scion xD
Old 02-25-2009, 01:24 PM   #29
ya, i agree....no gains even on the butt-dyno...i have one in the yaris and it still chokes past 5500 or 6000rpm - - i just bought it because i hate paying a toyota tech to install new paper filters when i can run w/ a k&n and clean it myself...
gains would be easier to get on larger displacement engines too....though i talked my dad into a k&n filter on his 3.8L (or is it 3.9?) v6 gmc sierra (2006, iirc) and i couldnt really feel a difference...but he says he gets a couple more mpg now...
Old 02-25-2009, 01:46 PM   #30
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I have a K&N airhog on my wrx for the past 5 years with no ill-effects. Like ChinoCharles stated, it's a race car, so whatever.
I got a Blitz LM intake on my yaris, and it seems to do the trick just fine. If I had'nt got it, I'd be rocking a K&N filter.
You haters are overanalyzing the situation. It's not like were talking about crank pulleys that throw off your harmonic balancer. They make balanced ones for race cars, but they cost 4x as much. IT is safer, as you have much more invested in the motor should it crap on you.
anonymous user is offline
Old 02-25-2009, 01:54 PM   #31
1stToyota
1stToyota's Avatar
Did it always choke past 5,500 rpms? Giving K&N their due credit, if you're going to notice an improvement that's where the car should feel better than it did before with the paper element.
At the risk of looking like a jerk it might be worth about 10 minutes of your time, a q-tip and some rubbing alcohol (or the CRC cleaner), because loss of top-end power sometime means dirty MAF. All you need is a small phillips screwdriver to remove the 2 screws. No harder to do then replacing the air filter. Might be worth giving it a try to see if that improves the top-end acceleration.
2008 Scion xD
Old 02-25-2009, 02:02 PM   #32
1stToyota
1stToyota's Avatar
I'm not hating K&N, just saying that MAFs get dirty enough to need cleaning, even when someone isn't using oiled elements, so going oiled just increases the risk. And I know because most of the tuneups that I do the MAF meter (w/ paper filter installed) is a lot nastier than the iridium and platinum plugs that I pull out with over 100k miles on them.
2008 Scion xD
Old 02-25-2009, 02:05 PM   #33
i found in a stock yaris the power just isnt there to redline...maybe 6000rpm is more accurate....maf might need cleaning too at this point....but i figure ill wait till spring....
i find with a proper intake the power runs to redline....
Old 02-26-2009, 12:08 AM   #34
anonymous user
Drives: 07yaris
I wasn't singling you out specifically, but i agree with your points.
I've never had a problem with the maf getting clogged up with oil, but have had carbon buildup problems with the IAT sensor on my wrx, and also water coming in the fenderwell clogging my filter after like 90 straight days of rediculous rainstorms.
Old 02-26-2009, 06:28 AM   #35
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
K&N Drop in Filter FTW!
id3379 is offline
Old 02-26-2009, 03:26 PM   #36
Yaribhini
Drives: Yaris
Interesting that almost everybody missed the point that I tried to make and that is not that the K&N flows less than paper media, it is that it does so at the cost of filtration. A K&N let's more in which constitutes a dirtier motor and throttle body. I'd love to hear the arguments for needing more airflow for this 100hp air pump. Please don't kid yourself into thinking that the K&N is giving you better results. The only think that it's doing is making your motor and throttle dirtier.
Chino,
I assume you have your Yaris on the track often? That K&N filter must have you blowing by all the Porsche's and BMW's!?
C'mon guys, stock paper media is where it's at with this Yaris. That's a "no brainer."
Yaribhini is offline
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 01:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 07:36 PM
Cold Air intake with k&n filter _S7V7N_ Performance Modifications 23 12-19-2008 03:36 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 03:00 AM
K&N 57i filter for TS 1.8 jim TS Performance Modifications 5 06-24-2007 06:00 PM
