![]() ![]() Drives: 07SedanS06Taco Join Date: Oct 2008
ignition keyring light
Wondering if anyone has added a ignition keyring light?
I'm getting old..Can't see in the dark I did a search here and nothing. I found one thread on Scionlife for a XA/XB, being a toyota product. http://www.scionlife.com/forums/viewtopic.php?t=81354 Thanks |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
Garm have you gotten white??? (I feel like chase you around the forum
R-CaT Project Yar 2ZR |
Hi guys just so you know , this will not fit the yaris if you have
factory keyless entry as there is a start disable module in this area . picks up trasnponder signal from the key. Last edited by 1NZYaris1; 04-04-2009 at 08:09 PM. |
#5 | |
Blue will match my led mod (radio, speedo cluster) perfectly. Can you confirm this will fit a U.S. sedan? ![]() and is this tied into the dome light with instructions? I dont believe U.S. model has what 1NZyaris1 is talking about. Thanks |
HacKers WanTed!
Thanks! that way I don't to buy it for the SD just the HB
it will fit us sedan. all sedan prior to 09
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Bummer. Was just looking at it at the Micro Image online store today, but my '09 has factory keyless entry. |
#9 | |
If not, then the ring will fit your yaris. note: all new cars sold in CANADA have an immobilizer. it is required by law. |
Yeah, I do have that red LED on the driver side end of the defroster vent right below the windshield.
#11 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
![]() Thanks for the heads up anyway, 1NZYaris1; saves me the trouble of returning the part.
Benggolf2 |
#12 | |
it had been run over , broken into about 6 peices ,so i super glued it back togeather just to try it , fitted great it even lite up okay but i had to remove the factory part from the barrel hense the car would not start. as the inner ring looks like it gets it's earth from the ing barrel. |
#13 | |
all new cars sold in Canada since 08 have an immobilizer, regardless you have keyless entry or not. even then 9999$ hyundai accent have an immobilizer. |
#14 |
Thanks for all the great info guys, I will post the warnings withe the product description.
I'm still not clear though, why you couldn't just wire it to the dome light wiring? I'm reading that "it won't work because", but I don't understand completely. Will it just not fit?
#15 | |
see pic above. |
#16 |
My '09 LB has a transparent plastic ring where this ignition key light would go. Couldn't we just remove that and pop this ignition light in place of that transparent one I have? Or is the keyless entry still going to prevent that?
#17 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
You don't need an ignition keyring light. Just above the rear view mirror are two lights. One will shine right on the ignition keyring when activated.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#18 |
Of course we don't need an ignition key light. Who told you we needed one?
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| LED ignition light | Jsword | Cosmetic Modifications (Exterior/Interior) | 17 | 10-21-2008 06:54 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
