Old 04-21-2009, 12:04 AM   #11
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by schleppy View Post
My only concern with a filter magnet is that if enough gunk were to build up in the filter, the magnet would hold it all in the filter in the spot with the magnet. It could potentially reduce the flow of oil.
If you've got that much metalic "gunk" building up in your filter, you've got far worse problems to deal with.
PetersRedYaris is offline   Reply With Quote
Tags
magnetic drain plug ap03
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
Magnetic Drain Plug Source? blacksan DIY / Maintenance / Service 9 05-11-2007 08:01 AM
