Old 01-09-2007, 07:20 AM   #19
nick34
nick34's Avatar
Drives: '06 Yaris
When you switch on your small lights, the pic of the foglight will light up.
When you switch on your headlights, the square will light up
When you didnt switch on any of your lights, there wont be any lights on the switch
Ive DIY mine foglights on my Yaris.
Defi link BF system (Water temp, Oil tamp, Ext temp) , Summit Front Tower strut bar
Summit 2nd link sway bar , Summit Engine Sub Frame bar
16" Weds Sport SA70 BLC , TRD replica extractor
TWM short shifter kit , Skunk 2 10anniversary gear knob
Sparco Torino 2 , Sparco Carbon Fibre Pedal
Webasto sunroof , J's Racing GT Wing
Apexi RSM - Black , Apexi Turbo/NA Timer - Silver
Pivot Shift Lamp
nick34 is offline   Reply With Quote
Old 01-09-2007, 10:37 AM   #20
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
So when you depress the button, the fog lights turn on and the green rectangle lights up?
Old 01-09-2007, 02:58 PM   #21
nick34
nick34's Avatar
Drives: '06 Yaris
when i depress the button without turning my light switch, the switch nor the foglights light up
Ive connected the switch to my parking light (small headlights) which means if i were to on my foglights i need to on my parking lights .. you can even change the switch to other kinds of switch like the one i did for my interior neons ..
Pivot Shift Lamp
Old 01-10-2007, 06:49 PM   #22
fantabulousbaby
Drives: 3 series
For my Ebay OEM fog lights, there is always a dim green glow on the switch as long as the car is turned on. When the lights are turned ON, the green glow gets brighter and the tiny rectangle above the fog light symbol glows as well.
I know for sure one light is brighter than the other, not because of my camera, it's really obvious by eye at night.. it irritates me but I don't necessaryily want to go back to that guy to ask what happened. Maybe the one bulb was faulty, wasn't on tight, or wiring? Or maybe cuz they're cheap bulbs and I need to buy some HID's. Really, I turned them on at nighttime and currently those bulbs don't do much (no, it wasn't foggy but in my previous cars they also worked well as extra lighting at night). For now, it's just for looks and I don't turn them on- I just hated seeing those black plastic covering over the 'holes'.
fantabulousbaby is offline   Reply With Quote
Old 01-11-2007, 06:53 AM   #23
Violin
Violin's Avatar
Thanks.
Have the installer take a look. It's possible that the one bulb isn't installed correctly and is just sort of hanging in there - it wouldn't be waterproof.
Old 01-12-2007, 05:25 AM   #24
nick34
nick34's Avatar
Drives: '06 Yaris
Originally Posted by Violin View Post
Thanks.
if you are using the above foglight kit, check if the green wire is connected to the parking lights wire. It should be green in colour.
Step by step guide to install a foglamp kit
Full Kit
The switch
Two sets of harness
White molex connector connect to 2nd set of molex connector
C shape clip connect to ground (Chassis)
2 Black holders for H11 bulbs
Green wire to parking light wire which can be found just behind your headlight assy.
Blue wire to Batt
Black connector to relay
White molex connector connect to 1st set of molex connector
Green connector connect to the switch on your dash
The Relay
For the switch wire, you need to cut a hole on a rubber seal which is available on your firewall (your firewall should have 2 rubber seals) to pull the switch wire to your dash. Do this before connecting the switch.
Please take note that you are to cut a hole just enough for the wire to go through and not too big. If you cut a big hole, you will end up getting more engine noise in the cabin.
Also take note that the batt wire will be the last thing to connect.
After fixing on every connection, do a test on the foglamp to see if it's working before you put the bumper back so as to save time troubleshooting should there be any problem.
If anyone need more explaination feel free to PM me.
Pivot Shift Lamp
Old 01-12-2007, 09:14 AM   #25
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
More pictures...
-- Blen
Old 01-14-2007, 12:33 PM   #26
St_G
Drives: Black 2007 Yaris Liftback 1.5
Any chance for a more detailed step-by-step breakdown of the install? Perhaps with pictures to explain what you mean? Some of the language seems a little unclear.
St_G is offline   Reply With Quote
Old 04-18-2007, 01:09 PM   #27
nick34
nick34's Avatar
Drives: '06 Yaris
Originally Posted by Blenjar View Post
More pictures...
-- Blen
sorry for the late reply
will post up more pictures when im doing installation for my friend.
Currently ive fixed up 4 Yaris with the kit that I posted
Pivot Shift Lamp
Old 04-18-2007, 01:20 PM   #28
DJ_Trizzak
DJ_Trizzak's Avatar
Drives: Yaris 07 Auto CE -Blazin Blue
check PM - thanks
myspace.com/djtrizzak | epik.ca | track1.ca |
DJ_Trizzak is offline   Reply With Quote
Old 04-01-2009, 05:14 PM   #29
Rnankoo
Rnankoo's Avatar
Drives: Toyota Yaris meteorite silver
if u connect the green wire to the battery wat would happen ??
Rnankoo is offline   Reply With Quote
Old 04-28-2009, 10:14 AM   #30
marktvb
Drives: yaris
would u mind to post some pics about how to connect each wires
it is the most difficult part for me
now my switch was on but the light still not work
hope u can teach me to solve the problem shortly
thankyou
marktvb is offline   Reply With Quote
fog lights to be installed in Perth, Please help ASHRAF Australia 11 01-13-2007 09:54 AM
EBAY OEM BUMPER FOG LIGHTS Wayside General Yaris / Vitz Discussion 41 01-09-2007 12:52 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
"OEM" fog lights from ebay drell42 Cosmetic Modifications (Exterior/Interior) 5 07-28-2006 09:21 AM
Liftback Fog Lights on eBay Chris07LB General Yaris / Vitz Discussion 8 07-24-2006 07:06 AM
