Old 05-19-2009, 12:35 PM   #4
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
The little piece below the red comes off first. Pull on either side of it.
The two pieces on the right and the left side of the red come off next. Use both hands, one toward the top, one toward the bottom and pull out firmly.
Then above the red, the part that is level to the ground and also surrounds the console gauges comes next. Pull toward yourself.
Then the top piece of red is next. You'll need to unplug the 4-way flashers from behind before it lets go.
And last, the bottom piece of red. You'll need a small flat head screw driver to remove the knobs from behind.
The two red pieces will be the hardest to get off but all the parts just snap out and back in. Reverse the procedure to get everything back in. Good luck!
nick.dollimount is offline   Reply With Quote
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
How do I remove "Instrument Panel Finish" markitect In Car Entertainment + Electronics (audio / video / alarm) 3 11-26-2008 04:27 PM
AC Panel Question slvryaris DIY / Maintenance / Service 1 09-04-2007 07:16 AM
Removing Door Panel KSIbucky DIY / Maintenance / Service 7 10-04-2006 05:14 PM
Black Center Panel for Yaris Liftback RoninMax Cosmetic Modifications (Exterior/Interior) 25 08-31-2006 05:53 AM
