195/60R15 is alright, but when getting tires for the summer... aren't we supposed to look for a lower sidewall? :)
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Depends. Sure, larger sidewall ratio = more flex, but stiffer tire in the first place = less flex so it can all balance out.
As I said, 195/50-15 is tempting for summer tires for just that reason, THAT is a sweet spot for summer-tires, 195/60-15 is a sweet-spot for top-end all-seasons.
#3 | |
195/50/15's are too short. |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
195/50/15 is only .3" smaller diameter than the stock 14" setup of 175/65/14
Where is Oahu?
^ great info!
![]() ![]() Drives: 2008 Yaris Meteorite LB Join Date: Feb 2009
Tire Size...
I was just looking at http://www.miata.net/garage/tirecalc.html today investigating what tire I would get to replace my 185/60/15s. Mileage is my primary concern since yet again gas prices have risen to $2.95 here in lower Michigan. Every tire I have had in the older 70 & 60 series has worn poorly. If I was picking a 15" tire for my Yaris today I would get a Goodyear Fuel Max 195/65/15....more tire height, less revolutions per mile=more mpg. Not a lot maybe...but 2% or close to it. It seems like the majority of Yarisworld prefers the cooler looking wider series tires. Perhaps our Hypermiler members could shed some light on this.http://yarisworld.com/forums/images/smilies/biggrin.gif
#7 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
if your looking for mpg, and mpg only; a skinnier tire is more important, not a wider one. less rubber, less friction. and a taller tire does exhibit less rotations--but in town driving may suffer from you trying to overcompensate and is generally not a huge factor unless highway is your mainly your thing.
the standard prius has (to my knowledge) 185/65/15. i'd shoot for that if fuel was your concern-- someone on a forum mentioned goodyear integrity's as a good tire for this application, i'll see if i can find a link just remember, you'll be travelling faster than your speedo reads (@ 60mph = ~62mph) |
| Bulb Replacement Guide (led Sizes) | theFEVA | Cosmetic Modifications (Exterior/Interior) | 113 | 02-28-2017 12:02 PM |
| OEM Tire Replacement | mm34b | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 03-10-2009 08:02 PM |
| TIRE Replacement | buchieboy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 02-04-2009 12:52 AM |
| Tire diameter list | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 06-04-2007 04:03 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
