#289 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
I gave up on the 1ZZ for the 2nd time. No matter how many turns I gave the idle screw, after a while the engine would settle back down to around 500 RPM, shake/shudder, rev up to 1,000 RPM, and then repeat the process until I either started moving or turned the car off in frustration. I hate all the problems I'm having since the performance of the the 1ZZ really is noticeably better than OEM, but I can't take the way it idles. I was also getting the heavy jerking whenever I took my foot off the gas.
#290 |
you might have gotten a bad throttle body. maybe you should order the one through cali yaris.
#291 |
I don't think it's that, since the TB was working perfectly until I disconnected the battery. I wasn't getting any oscillation, jerking, weird idling, or CEL... then I pulled the battery cable and all these problems came out of the woodwork. I might try the swap again down the road sometime. Where can I get the Micro Image one? I don't see it listed on his website. Is it new or used/refurbished?
#292 |
It's a 1zz TB, with the Yaris chip module already swapped on...also, we remove all of the epoxy on the idle set screw and make a preliminary adjustment to get you in the ballpark.
#293 |
finally installed my 1zz tb after months of it sitting in my room. no CELS. warm idle at 2500rpms, then within seconds drops to 2k rpms, and then idles smoothly at a warm idle of 585 rpms. Didn't adjust the idle screw, and I didn't switch the chips; I think i've lucked out....
Drove the car after and ran it hard and conservatively, no problems! niceee edit: Still running good. I don't really notice an increase in power? I remember looking at Yoda's dyno sheet that he did after he added the 1zz TB, and he got a gain of 3 whp. Unless I got less of a gain, I can't really feel 3 whp added to the existing. However, if the car keeps running with no problems for a couple of weeks, I plan on taking it to get dyno'd. Now that I have my 1zz injectors, I will be able to successfully do three pulls and hopefully hit 140whp now with the 1zz TB! :) Last edited by PETERPOOP; 07-05-2009 at 08:48 PM. |
#294 | |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
you'll also need either 6 rivets and a rivet gun or 6 x small bolt and nuts for the "chip swap "
Garm is permanently high because he is the king of smokin' deals! |
#295 |
I used 6-32 allen head cap screws and jet nuts on mine. Makes for a realy clean job and the jet nuts are self-locking, so no worries about the screws coming loose.
#296 |
I used to have 1700 posts
where the hell did the diy go?
#297 |
t-sport is at it again; deleting everything he posts. i wouldn't think he'd delete this!
#298 |
SIPNDEW
why did he do that?
#299 |
ditto
#300 |
Heart Up! Vitz
#301 |
I've got close to 10,000 miles on my chipped 1ZZ TB, so I don't think it went bad on him.
#302 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
I'm hoping he just removed it because so many are having issues and not because he is being a pissant...
#303 |
i just did a swap last night from the stock throttle position sensor to a scion tc throttle body. i havent put the throttle body on yet to see it worked though. my corolla throttle body didnt set any cels when i installed it as is
#304 |
my 1zz throttle body that i put on without switching the chip or adjusting the idle screw and was running perfectly for the last two weeks has just turned gay on me. It started oscilating the other day, and i unplugged the battery, replugged it and it was fine. However, again it is now back to oscilating and i can't disturb it by tapping the gas to interupt it. my only hope now is to do a chip swap; but i don't think i want to.
#305 | ||
Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
#306 |
| 1.8L Engine Swap, Possible? | Yaris T-Sport | Performance Modifications | 4 | 05-06-2007 06:57 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
