Old 06-11-2009, 12:09 AM   #19
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
AFAIK, all ECUs have a programmed curve for maximum advance at an optimal performance level, with a knock sensor that retards the spark a bit when detonation occurs.
Yaris Hilton is offline
Old 06-11-2009, 01:10 PM   #20
intake
intake's Avatar
Drives: yaris 2 1.3 mmt
dejavu...is the 10% increase compensate for the extra cost of the fuel..?? just curious.
in my country the high octane fuel cost only 4% extra
here in italy we have 95, 98 and 100 octane fuel.
98 do not cost too much, only 4% more, but i'm experiencing 10% and more fuel saving.
100 octane is too much expensive, and it's used only by some rich people on ferrari
in the USA how much octane u have?
Yaris 2007 mmt 1.3 , denso power iridium, pipercross air filter, purplepower 10/40 motor oil + zx1, simoni racing silencer, eibach , henry hausen wheels, modified air box, trd logo,oversized oil filter.
intake is offline
Old 06-11-2009, 11:23 PM   #21
Yaris Hilton
Smile
We have a different rating method. Our 87, 89 and 91 octane ratings at the pump are comparable to your 95, 98 & 100.
Old 06-12-2009, 09:38 AM   #22
actually there's about a 5 point difference
eTiMaGo is offline
Old 06-12-2009, 11:42 AM   #23
IllusionX
Drives: 07 Yaris Sedan Aero
guys... keep in mind that higher octane fuel might have cleaning additives and possibly less E85 than regular fuel. This is just some reasons why you get better fuel economy with higher octane in an economy car like the yaris... that do NOT require premium.
IllusionX is offline
Old 06-12-2009, 11:59 AM   #24
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
More important to buy top tier fuels, i.e., quality from Chevron/Phillips and a few others than to play with octane, IMHO. Every mechanic I've talked to and a few were Toyota mechs. said don't waist you're money unless the manufacture recommends or sometimes specifies higher octane, or the engine is pinging. Hope this helps any fence sitters-I've been there myself.
UTVitz is offline
Old 06-12-2009, 12:48 PM   #25
2009Toyotoad
Drives: 2009 Yaris 3dr
Maybe instead of MPG we should be looking at $ per mile. Just a thought. What I think we all want is the lowest cost of ownership, but I could be wrong.
2009Toyotoad is offline
Old 06-12-2009, 01:26 PM   #26
roxy1
Drives: 2014 yaris 5 speed
is their any evidence higher octane fuels use less ethanol? ive seen more indications that higher quality fuels have the additives regardless of octane. i know for a fact the stations i use have cleaning additives in their 87 octane.
since there has been some consensus from more knowledgeable people that higher than 87 octane can actually reduce your mileage in the yaris (some forum members have already shown this to be so) then the lowest cost of ownership, fuel wise, doesnt even require any thought whatsoever.
Octane Myths
• High octane gasoline improves mileage.
In general, if your car is designed to run on 87 octane gasoline, high octane gasoline will not improve
mileage. If switching to high octane gasoline does improve mileage, you might find that your engine, or its
control systems, need repair.
• High octane gasoline gives quicker starting.
No, it doesn’t.
• High octane gasoline increases power.
If your car is designed to run on 87 octane gasoline, you shouldn’t notice any more power on high octane
gasoline. Again, if it does make a noticeable difference, your engine, or the engine’s electronic control
systems, may need repair.
• High octane gasoline has been refined more – it is just a better product.
Additional refining steps are used to increase the octane; however, these additional steps do not necessarily
make the gasoline a “better” product for all engines. They just yield a different blend of hydrocarbons that
burn more slowly. The additional steps also increase the price.
roxy1 is offline
Old 06-12-2009, 02:08 PM   #27
intake
intake's Avatar
the extreme advanced electronic management of the yaris can see wen you use high octane fuel, and change it's timing in spark plug lightining, so you have more power
intake is offline
Old 06-12-2009, 03:59 PM   #28
doublewam
Drives: 2009 Yaris
Ever since I filled my Yaris's tank with milk, I haven't had to fill it again...
...I haven't been able to go anywhere either.
doublewam is offline
Old 06-12-2009, 07:11 PM   #29
roxy1
roxy1 is offline
Old 06-13-2009, 12:22 AM   #30
Yaris Hilton
Smile
Not so. The U.S. rating is the average of the Research and Motor octane numbers. The European numbers quoted above are Research Octane numbers.
Old 06-14-2009, 11:24 PM   #31
EdgarTRD1.8
Drives: SR5 Hatch Back 82' 3TC 1.8
Send a message via MSN to EdgarTRD1.8
I think high octane fuel will not help on fuel economy, because the octane is the measure of the self evaporation of the fuel in comparison with the compression. Low compression cars use regularly regular fuel because the octane is low. If you put high octane fuel into a low compression combustion chamber, when the piston is compressing the air and the fuel, the fuel will not turn into gas stage completely. So will be liquid fuel yet on the chamber and when spark fire probably doesn't burn the fuel completely (the fuel burn in both stages, liquid and gas, but in gas stage burn faster than liquid stage). The engine will not work at high efficiency like will work if is burning the entire fuel. High compression and turbo applications need high octane fuel for the compression, higher compression turn the fuel in gas faster. If you use low octane fuel in high compression and turbo applications probably the fuel will self evaporate too fast and the piston will knock.
So if the car is not working at it high efficiency level i think it will not has fuel efficiency. The car will not work forced with this high octane "mood", but will not work like is suppose to do.
Some guys here in Puerto Rico tested them cars in a Dyno and proved that putting higher octane on the cars don't bring any HP gain, they proved with different octane booster and obtained no gains. You can use octane booster if your car has high aftermarket compression piston or turbo. I know you are talking about efficiency but I comment it for the explanation I put here is in the same way.
Tooling and die the world
EdgarTRD1.8 is offline
Old 06-15-2009, 05:37 AM   #32
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I never did understand why people buy a cheap reliable economy car then spend $0.20 more per gallon to put in premium fuel on the mistaken assumption that its going to make the car go faster and get better mileage.If you wanted a faster car buying a Yaris is a poor choice.
PS,your premium gas may only be 4% higher than regular but over the life of the car that will amount to some serious unnecessarily spent money.
jambo101 is offline
Old 06-15-2009, 09:31 AM   #33
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
Originally Posted by roxy1 View Post
buy higher octane, believing mileage will increase. trying to prove it now driving more conscientiously. mileage increases. kind of a self fulfilling prophecy. not due to higher octane. no scientific explanation will explain higher mpg's from higher octane.
now im going to go.....on myself......as punishment for getting sucked into this ludicrous discussion.
Well, I'll get sucked into this discussion:
At work I drive a 2005 Buick AWD van with a large v6 engine, and average between 5,000 and 6,000 miles a month. I have had time to 'experiment' with octane ratings. For two months I used premium grade gasoline and averaged 21.8 mpg. For two months I used the lowest grade and averaged 21.9 mpg. My trips are mostly highway miles with about 5% city driving. I cover the state from corner to corner so all my trips are about the same. I use mostly the same brand of fuel. The weather conditions were about the same when I 'experimented.' I drive fairly conservative with the work car just as I would with my own car.
I see no real difference between mileage and octane rating. The van must compensate for the octane and adjust accordingly. I notice no knock on any of the gasoline changes.
JUST my 2 cents worth.
andaconda is offline
Old 06-15-2009, 12:34 PM   #34
jambo101
jambo101's Avatar
Originally Posted by voodoo22 View Post
Like when my brother bought a $55k BMW and put in regular. What a tard.
My father in law had this strange habit of filling his pickup truck with the cheapest oil he could find usually the $0.75 a quart stuff and fill up his gas tank with the most expensive gas he could find.
jambo101 is offline
Old 08-05-2009, 02:01 PM   #35
Marthos
Marthos's Avatar
Drives: 07 3Dr LB
Octane is a rating, of a fuels ability to combust.
The higher the octane rating the harder it is to "burn" that fuel.
The higher the compression, the higher the octane needed.
When a low octane fuel is compressed to high it will self combust, causing preignition, that is when the fuel burns before the spark plug fires and the piston is on the downward power stroke.
A supercharged engine needs high octane fuel so the compression does not ingnite the fuel before the spark plug fires.
Always use the recomended fuel octane rating listed in the owners manual.
Only go up to a higher octane if you hear Pinging, as this can lead to major engine damage.
Marthos is offline
Old 08-05-2009, 03:21 PM   #36
Yaris Hilton
Smile
Higher octane doesn't mean it's harder to burn, just that it's slower to autoignite when heated to a temperature where that can occur.
Preignition is different from detonation in that detonation occurs after the spark has fired, in the part of the fuel/air mixture that hasn't yet been reached by the expanding flame front from the spark. Preignition is caused by hot spots in the chamber igniting the fuel before the spark fires. High octane won't fix that.
going from 91 to 87 gave me CEL! FLAME ON enviri General Yaris / Vitz Discussion 28 05-24-2009 09:42 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Premium Gas Kaotic Lazagna DIY / Maintenance / Service 215 08-15-2007 03:24 PM
octane at high altitude. chibianh General Yaris / Vitz Discussion 10 05-16-2006 12:47 PM
