Old 06-16-2009, 10:53 AM   #5
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
There is a drain for your air conditioner coils-as the warm air passes over these super cold coils moisture forms-just like on the outside of a glass with a cold drink in it. The moisture forms enough to drip into a box and should go out a small tube to exit the car. But, if this tube has debris in it, i.e., leaves, paper,or whatever, the water is trapped and starts to grow moldy. I do not know where this tube is located to check-it is usually traceable from under the dash. At most you should only have to take the glove box out just like you were going to change the filter. But if you're not sure the dealer should fix this under warranty. Because, stuff should not get in there to clog it and if it is they need to find out why. Check your intake at the base of the windshield on the outside where the slots are-there should be a screen in it to protect from large stuff getting in there and if you have a filter in your ventilation make sure it's not falling apart-that's the only reason I can think you'd find paper in there. good luck.
UTVitz is offline   Reply With Quote
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
