The hose is probably partially blocked, causing water to backup in the condensate pan. Find the output of the hose under the car and stick a semi-rigid plastic item up it (long tie-wrap for example).
| Air Conditioner Noise & Leak? | Dawn Eshelman | DIY / Maintenance / Service | 116 | 07-21-2015 01:22 PM |
