#55 |
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
Pics!! :D
#56 |
Slowy getting there
Haha! Talked my boss into letting me do them at work. Working on a car is so much easier when you have a lift! Ill have to take pics when I get home sorry they won't be before and after.
#57 |
it's all good, I just like seeing pics of Yari with proper fitting wheels!
#58 |
I used to have 1700 posts
which spacer with these wheels
monarch nilo 16x8 +20 offset 215/45/16 planning ahead of time, dont have tires for them yet. already planning on pulling and rolling fenders. just curious as to whether i could get away with the 13mm spacer |
#59 |
toyota
#60 | |
you're going to have to do some work to get that fit as is, going with our hubspacers before you do the install will allow you to do the required mods to make it fit. a little extra pull and our camber shims will round out the car nicely. you may want to go with the 10mm spacer although if you're looking for a much more aggressive stance the 13mm would do it. either way spacer or no spacer you've got a lot of work to do ![]() hopefully we'll be testing some 15x8 +20mm front and 15x8 +10mm rear wheels soon. :) |
#61 | |
#62 |
Slowy getting there
Finally a pic with mine installed!!(13mm BTW)
#63 | |
thanks for your input. i'll be placing my order within the next few weeks |
#64 | |
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
#65 |
yes we ship internationally.
I'll shoot you an email with the info. :) |
#66 |
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
The statute quoted is under tires and wheels. These spacers are hub spacers, not wheel spacers. It appears sufficiently ambigous to be argued either way.
#67 |
and painted black, they'd NEVER be spotted in an inspection.
#68 |
Beast
yep yep pretty sick
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#69 | |
#70 |
LOL @ the irony of the name of this thread
#71 |
37HSSV
I believe the 4 are camber shims...for use on the bottom only?
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
#72 |
sabretooth is right, those are "optional" camber shims that go on the lower bolts (2 each side) if you choose to add a little rear camber to the mix. we're including them now for free since people seem to be rubbing more on one side of the car more than the other.. (passenger side, right guys?)
