![]() ![]() Drives: 2009 Yaris 4dr Sedan Join Date: Mar 2009
Painted my Engine Cover
Here are the pics.
I tried to stay simple and make it clean looking. ![]() ![]() ![]() Blue |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Nice.
I think you are right.
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Did you use house paint or something?? I'm scared to paint mine now.....
#5 | |
I wet sanded the entire cover with 400 grit sand paper. cleaned it and wiped it down with a tack cloth. Sprayed it down with adhesion promoter and let it dry. Then I sprayed it with Red Engine Enamel (gloss). I wet sanded it down with 400 grit paper again, and then sprayed it with the engine enamel again. I hand painted the black on the VVT-I and logo with gloss black. I also sanded the nuts that hold the cover down and sprayed it with flat black and then clear (not high temp paint). I like the orange peal look on the cover because it still makes it look plastic, like it was from the factory (in a sense). Blue. EDIT: Looked at my original photos and the Auto setting just did not do well, I will take pictures in daylight. I took the pictures at night in the garage..... Last edited by Blue_dragon_192; 08-10-2009 at 01:05 PM. Reason: Update about the photos. |
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 11-30-2013 11:07 PM |
| Question about painting the Engine Cover | Blue_dragon_192 | Cosmetic Modifications (Exterior/Interior) | 11 | 08-05-2009 12:45 PM |
| Engine cover for S/C engine | LtNoogie | Cosmetic Modifications (Exterior/Interior) | 84 | 05-04-2009 08:41 PM |
| Painted Engine Valve Cover: Round 2 | m911gt | Cosmetic Modifications (Exterior/Interior) | 46 | 01-12-2009 08:17 AM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
