Old 08-11-2009, 08:03 PM   #14
Jrilla
Drives: 09 Yaris 4Dr Sedan
CTScott can you post a picture of your switch that you put next to the dimmer? And also a link to a similar switch? If it looks good on your's I might consider this location. I just can't imagine cutting a hole in my dash that would look like it was from the factory.
Right now I am considering just using the parking lights to trigger the fog lights (with my own relay for now) to see if I like the look of the aftermarket fogs I have installed. If I like them I will want to find a switch that works. Otherwise I will just get the entire kit and then buy the 09 trim pieces from toyota (only $22 + tax).
I have seen switches that don't separate the illum from the switch, and it seems like there should be a distinct difference between the switches that do this and do not. Any ideas?
I ordered the relay already so I could get this install going, and since i am already going to install a remote starter, i might as well just put an extra relay under the dash for to turn on the fogs whenever the parking lights are on just to see if I like the ones I installed. They look good now, but I haven't run any juice to them yet. They may be completely off line for all I know. And since I JB welded them into the blank trim pieces, there is no adjustment. I will post back once the install is complete, but for now, thanks for the input. If you find or have a switch that you know will work, let me know.
Thanks again.
Jrilla is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
a little fog light help please.... 90tsi DIY / Maintenance / Service 6 07-22-2009 11:46 AM
fog light install experts please help tber DIY / Maintenance / Service 5 02-26-2009 02:47 PM
