Half a Bubble Off Plumb
In many cars the hot water always circulates through the heater core. Air doors control the air flow through the heater core and air conditioning evaporator. I'd expect that's how it works in the Yaris.
Check the radiator cap to make sure the coolant is full to the top of the filler neck. There should be no air space in the cooling system. As it heats and the coolant expands, some is forced out into the overflow tank, then is sucked back in when it cools and contracts, so there can be no bubbles. |
| electrical problem with car need help badly!! | Adriaan | DIY / Maintenance / Service | 20 | 05-07-2010 12:40 AM |
| Weird door locking problem, electrical? | davembfan | General Yaris / Vitz Discussion | 19 | 09-30-2009 02:50 PM |
| Yaris 06 H/B Engine Cutting out problem.. | Farenheit | General Yaris / Vitz Discussion | 3 | 09-14-2007 01:21 PM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 06:00 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
