Old 08-21-2009, 10:32 AM   #19
MGargano
Drives: 2009 Yaris Hatchback
Ordered. CTScott you were definitely right about how addicting it is to abuse your car's electrical system. Now I'll have something to tinker with while you figure out what's wrong with my OC ECU.
Old 08-21-2009, 10:58 AM   #20
Nice! That's why I would never lease a vehicle. There is no way I could prevent myself from monkeying with the electrical system.
Old 08-21-2009, 11:00 AM   #21
MGargano
I've always been more into the mechanical stuff, but I'm starting to really get into the electrical side with this car. Any chance you've figured out the push-button start? I think that's my next project after seeing echo's thread.
Old 08-21-2009, 11:36 AM   #22
Push button start would be fairly easy to do. To really do it right would require a bunch of parts from one of the markets where it is available.
The problem is that for our USDM cars you would still need to stick the key in to unlock the steering. You could mechanically bypass the steering lock, but then you make your car a whole lot easier to steal. Also, the OEM system uses an RFID smart card (along the same lines as the key transponder). You'd really want to implement something like that to make the car less grabbable as well.
Old 08-21-2009, 11:41 AM   #23
MGargano
Hmm it looks like I might table this idea for a while then, at least until I get the SRS and now the windows completed.
Seems kinda silly to have push-button start if I still have to use the key to unlock the steering. And I'd hate to make my car more vulnerable to theft.
Old 08-21-2009, 01:44 PM   #24
PatrickJohnson
Drives: 2008 Yaris LB
couldn't you get something like what the maximas do now, where you have a proxy chip on the key so that you can push button start it as long as the key is in the car (like in your pocket)?
PatrickJohnson is offline   Reply With Quote
Old 08-21-2009, 01:55 PM   #25
Yes, that's the RFID device. That requires an RFID tag and some type of reader.
Old 08-21-2009, 02:05 PM   #26
MGargano
How readily available are these RFID devices and readers?
Old 08-21-2009, 02:11 PM   #27
Readily available. They are used in everything from the automated toll tags to ID badges to anti-theft devices in stores. The tags are typically very inexpensive (under $1 for passive tags). Readers can range from as cheap as $25 to $3000+.
Radioshack actually sells a development kit for $49 that includes a reader and two button tags.
Old 08-21-2009, 02:13 PM   #28
MGargano
I would definitely need your expertise with this, but if it's something I can get my hands on easily, I might have to go for it.
Old 08-21-2009, 08:12 PM   #29
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
I know newer Vettes have no key what so ever all you have is a key fob that unlocks the doors, steering and they have push buton start. That I think be cool on a yaris
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 08-21-2009, 08:28 PM   #30
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by DevilGirl View Post
The boy's 09 Jetta Sportwagen TDI has the safety feature with the auto up that stops the windows when there's something in the way, like a child's finger.
Would be nice if Toyota had that too... The technology's there, why can't they use it?
i actually was looking into getting the in channel window vent shades from toyota. The local dealership told me if I had auto-up windows that the in-channel visors might cause the window to not fully roll up.... dude made it sound like the toyota auto-up windows had a sensor installed to back off if it met any resistance.
I don't have auto-up windows.... just auto-down so it doesn't matter to me...
Old 08-22-2009, 01:22 AM   #31
MGargano
BTW, I apologize for completely jacking this thread
Old 08-24-2009, 02:56 PM   #32
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
the 09 Rav4 i rented has auto up/down drivers window. I actually got annoyed with it trying to only open the window a crack to vent the LA heat. I looked like an idiot rolling the windows up and down trying to figure it out.
Check out my Build thread:
Old 08-25-2009, 04:19 PM   #33
RedRide
RedRide's Avatar
Originally Posted by Sir A.Y. Atoyot View Post
Auto up would be dangerous for kids, so Toyota will never produce it. Lotsa luck wiring it up yourself.
I may be wrong but, I aways understood that auto up was always avalible for the JDM for most cars but never exported.
I guess the Japaneese liability laws are much different than in most countries.
I wonder if auto up is avalible for the JDM yaris?
Old 08-25-2009, 04:38 PM   #34
Maybe JDM kids keep their hands and heads inside of the vehicle at all times.
If it is available on the JDM Yaris, it would be a bit of an issue to put on ours because the master window control is on the opposite door. The $50 DEI module would definitely be the cheapest/easiest way to get auto up/down on all windows.
Old 08-26-2009, 09:16 PM   #35
MiniTRD
it's the MiniTRD
MiniTRD's Avatar
Drives: 2009 Polar White 3dr Yaris S
Send a message via MSN to MiniTRD
just chiming in
I just had a 2008 Scion tC.
On the drivers side are the two switches which both do FULL up and down. The passenger side has a single switch with Full up and down. There is no resistance sensing switch that I was ever able to tell. In fact you just kept holding the switch up or down to program the full open or close distance.
BTW I looked see if they could be adapted to the Yaris, but no go unless you want to do some soldering.
Clark
2009 Polar White 3dr Type S
it's the miniTRD
http://www.norcalcarstyle.com/minitrd/
MiniTRD is offline   Reply With Quote
Old 08-28-2009, 05:11 PM   #36
d.one
Drives: wht [s]
BEST thing is adding the DEI 530T (given that you have a Directed alarm).
d.one is offline   Reply With Quote
