Old 11-23-2006, 04:07 AM   #1
webmaster
BX
Send a message via AIM to webmaster Send a message via MSN to webmaster Send a message via Yahoo to webmaster
Computer
I want to install a computer into my car
i want the monitor to be a 8 to 10 inch touch screen
i want to use it to play
dvd movies
cds
mp3s
have various screen savers ect for effects
also be able to put pc games with retractabel controller
i need to be able to hook the audio of the computer to the sound system
the computer wil prolly be a laptop of some sort but it has to be intregrated with the dash entirely
im have much experience with computers but im a total newbie when it comes to cars
i wanna kno if this is a workable idea or i should attempt something else?
and ideas of getting started?
thx
webmaster is offline   Reply With Quote
Old 11-23-2006, 04:18 AM   #2
Bones
Bones's Avatar
Drives: 07 Yaris S Type
We use the Panasonic Toughbooks at work and it works great. The laptop has a docking station in the trunk and we use a remote mount monitor and keyboard. Wireless keyboard is possible. Panasonic's monitor also has touch screen. Depending on the size and type of screen you want to use it may or may not have touch screen capabilities. You would have to use the audio out of the laptop to an amplifier to power your speaker.
You can run any OS and use media player for your music.
Bones is offline   Reply With Quote
Old 11-23-2006, 04:26 AM   #3
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Looking to spend around $2,000??? That's about cheapest you can do it for!
Click Here:
http://www.azentek.com/webpages/atlas.html
It's the Azentek Atlas CPC-1000
I spoke to Chad Stayton and he was totally cool.
If you get in touch with them...Tell him Stephen sent ya!
Nutzoids is offline   Reply With Quote
Old 11-23-2006, 11:33 AM   #4
ChinoCharles
Drives: LB
That is . You could do it for half that easy... the most expensive part of the outfit is the screen, which will be about half of that.
That is, of course, if you don't use a laptop. You'll get a much cleaner, much more functional install if you go the desktop route. In fact, you can make a carputer look downright OEM.
I am also planning on doing a carputer install in the Yaris, being that I am a computer science major and have built my own computers since I was in high school. I have been reading up on it (slowly but surely) and have found that there isn't really that much involved. The hardest part about it is the power source and finding where you want to mount your peripherals.
You don't need a high-octane machine for a car. 1-2 GHZ would suffice, and you can get the proper AMD CPU in this range for under 50 bucks. Add in...
MicroATX Motherboard w/ built in video and six-channel audio
Hard drive... 100 GB or so
Memory... maybe a gig
DVD-ROM
A couple wireless controllers
You're at what, 300 bucks? Get a nice motorized in-dash touchscreen...
http://store.mp3car.com/SearchResults.asp?Cat=61
And you're still well under a grand. Should give you a couple hundred bucks for things like that power supply, wires, nuts and bolts, maybe an infrared device, etc...
The following link is Mecca for carputer buffs. Go make an account and check out some of the installs done in other cars. It will help get your wheels turning.
http://www.mp3car.com/
Old 11-24-2006, 10:01 AM   #5
Nutzoids
Nutzoids's Avatar
DVD-ROM
What do you know… Your wrong!
Motherboard & CPU: JetWay & VIA C7 Nano -$189.99
http://www.newegg.com/Product/Produc...82E16813153050
Memory: WINTEC AMPX 1GB 240-Pin DDR2 SDRAM DDR2 400 - $62.99
http://www.newegg.com/Product/Produc...82E16820161652
Harddirve: 100GB Western digital 2.5” - $79.99
http://www.newegg.com/Product/Produc...82E16822136005
DVD: Panasonic Slot Load DVD-ROM - $75.00
http://store.mp3car.com/ProductDetai...Code=OPT%2D002
Case w/ Power Supply: APEX DM-318 Black Steel MicroATX Slim Case - $44.99
http://www.newegg.com/Product/Produc...82E16811154062
Right there is $452.96 (did you want wireless internet or Bluetooth) add another $100
Plus your Monitor- Lilliput 7" In-Dash Motorized Touchscreen - $469.99
http://store.mp3car.com/ProductDetai...Code=MON%2D020
There is $922.95
Plus a shutdown controller- Micro Shutdown Controller - $41.99
We are up to $964.99
Power Regulator- Carnetix CNX-P1900 140 Watt 12V DC-DC Regulator – $99.95
http://store.mp3car.com/ProductDetai...Code=PWR%2D010
Now $1,064.89
To be honest I don’t even know where to start looking for all the cables, adaptors, spacers, screws, bolts, fans, connectors, and tools to get your PC to fit in your car and play out of your speakers.
But I’m guessing that should be around another $200-$300
So with that and Bluetooth and wireless we are looking at about $1,400
And that is the cheapest way…If you build the computer yourself and install all the components yourself!
Go back to school Junior… (Mr. Computer Science Major)
Old 11-24-2006, 10:13 AM   #6
Wayside
Wayside's Avatar
Drives: 07 yaris 5spd sdn
Yeah, I found that a bit unessacary as well.
Use an old laptop (ebay) and keep the os clean so it doesn't get bogged down (laptops and the 2.5" drive will take a little more abuse then a desktop and offer a built in battery backup).
Set the power scheme to switch to standby after 1-5 minutes when running on batteries and just shut it down when you park for the night.
Grab a $20 power inverter and hardwire it to a switched ignition source, plug your laptop brick in to it.
To save cash and fabrication time go with a 7" in dash VGA touch screen.
Should be able to do all that for around 1K...
Wayside is offline   Reply With Quote
Old 11-24-2006, 01:32 PM   #7
ChinoCharles
Drives: LB
There is $922.95
Now $1,064.89
CPU: AMD Sempron 2500+ Thoroughbred 1.75GHz Socket A Processor OEM
$44.00
http://www.newegg.com/Product/Produc...2E16819104204R
MoBo: PC CHIPS M825G (v9.2a) Socket A VIA KM266Pro Micro ATX MoBo
$25.00
http://www.newegg.com/Product/Produc...82E16813185082
Heatsink: Dynatron I51 CPU Cooling Heatsink - Retail
$18.00
http://www.newegg.com/Product/Produc...82E16835114032
Memory: BUFFALO 512MB DDR 333 (PC 2700) Desktop Memory - Retail
$54.00
http://www.newegg.com/Product/Produc...82E16820150065
HD: HITACHI Deskstar T7K250 160GB 7200 RPM 8MB Cache IDE Hard Drive - OEM
$54.00
http://www.newegg.com/Product/Produc...82E16822145091
DVD: ASUS Black 52X CD-ROM E-IDE/ATAPI CD-ROM Drive Model CD-S520/A5 - Retail
$12.00
http://www.newegg.com/Product/Produc...82E16827134012
TOTAL COST: $207.00 (before shipping)
SPECS
AMD Sempron 2500+ processor w/ heatsink
PC CHIPS MicroATX motherboard
onboard 6 channel audio
onboard video
160 GB 7200 RPM HD
DVD-ROM
512 MB DDR 333 memory
So yeah, there is your true basement-budget car PC. You wouldn't buy a case, because if you're trying to save money you could fab one up yourself. You'll want to anyway in order to make your mounting points for the computer components as shock-resistant as possible, especially if you have a suspension/drop.
As for your products, the CPU you chose was an off-brand piece of shit, your hard drive price was through the f'n roof, and the slim DVD-ROM wasn't necessary. All the money I just saved building my carputer the right way frees up room for an $80 WiFi car antenna. You could buy that just with the money I just saved you, and you'd still have some left over for some Chipotle and a blunt.
$200-300 for cables, screws, connectors... are you kidding me? You even had tools in there... I mean, did you include the price of a bandsaw to hack up all the MDF it would take?
I'm done flaming you, this is a waste of my time and I have lights to smoke. Just do yourself a favor and stick to what you know. It obviously isn't computers.
vodkalush, you're right... it would be quite the feat to fit a computer in the front of the car. I think the best bet is to house most of the components in the rear, maybe in the spare tire well. The only periphery you'd need access to is the DVD-ROM, so its a matter of finding a clever spot to mount that up front and running a whole lot of wire. Still, it can be done.
I have an idea for mounting the computer up front, but I would have to see a MicroATX board in person before I know whether or not it would work. You know that space underneath the climate controls, right below the 12V power outlet? There is nothing underneath there but shifter cables. You could fab up a case (assuming the board is small enough) and bolt it right though that thin plastic. Just an idea...
Old 11-24-2006, 02:25 PM   #8
Nutzoids
Nutzoids's Avatar
OK... Let me know how that works out for you Mr. Computer Science Major.
Old 11-24-2006, 03:26 PM   #9
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
snip...
Resident Shit Disturber knows his doo doo.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 11-23-2006, 01:47 PM   #10
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
The biggest thing thats gonna end up bothering you (at least it would me) is the PC boot/load time. You could rock a xbox with modchip, 100-200gig harddrive and xbox media center (about $300) and the boot time will be about 15-30secs vrs 1-2min (after everything is loaded into mem and what not) for a carputer. The one thing that you would probaly not like is the lack of touchscreen support... although after a little research you may even find it.
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 11-23-2006, 02:43 PM   #11
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
If you havent already read about this car in PASMag then PLEASE READ!!!!
This is about the most advanced system Ive seen so far and right up your alley.... The infrared keyboard idea is awsome (among everything else).
Theres no picture that I could find on the site of the keyboard setup but shouldnt be hard to find on the Net. It in the mag but that wont help you much unless you run out and buy the latest copy.
Heres the link nonetheless...
http://www.pasmag.com/article.asp?ID=390
mikeukrainetz is offline   Reply With Quote
Old 11-23-2006, 02:54 PM   #12
bonjournaste
Drives: Yarisless
What about a Mac Mini?
bonjournaste is offline   Reply With Quote
Old 11-23-2006, 03:05 PM   #13
mikeukrainetz
Thats what they used in the vehicle I posted above...
Old 11-24-2006, 06:39 AM   #14
spkrman
Drives: 1
to shorten boot time you keep the puter on standby, or hibernate.
www.mp3car.com really has all the info you need on this subject.
Old 11-24-2006, 10:59 AM   #15
vodkalush
I drive a yarrrris
vodkalush's Avatar
yah, I would love to see someone fabricate a oem style front face/case to fit into a yariii. Since, that will must likly never happen your better off getting the double din 7inch pc controller screen (with built in DVD) for $650+.
Also Nutzoids you might want to learn alittle about being a savy shopper, and not only look at one place for computer equitment on the internet... oh well I've given up on this idea still have the $650+ to waste on a touchscreen carputer controller thingy; so I'm not gonna be nice and search for better prices. But feel free to check either newegg.com and/or pricewatch.com .
and with that said, $1400 is "near" half of $2000
luck to those that do this, please post pics and info on your build
will work for parts
Old 11-24-2006, 09:35 PM   #16
ChinoCharles
Drives: LB
YOU KNOW?!?!?!
He should take elsteverino on a date.
Old 11-24-2006, 09:50 PM   #17
Nutzoids
Nutzoids's Avatar
I apologize to all… I was Wrong!
ChinoCharles- I stand down and wave the little white flag… Also as a sign of peace and gratitude I would like to purchase something for your Yaris… Perhaps some Grounding Wires? As a sign of friendship of course… We are all on the same side here (the Yaris Side) and should not be arguing over something so trivial…
Old 11-25-2006, 02:04 AM   #18
ChinoCharles
Drives: LB
Haha, its all gab dude. Don't take it to heart, and buy yourself some ground wires.
Trip Computer and External Temperature Display jodiem In Car Entertainment + Electronics (audio / video / alarm) 62 11-15-2012 11:06 AM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 10:14 PM
anyone installed a computer n touch screen yet? Blenjar In Car Entertainment + Electronics (audio / video / alarm) 0 06-12-2006 11:06 AM
Cold Air Intake ? pegcityrs Performance Modifications 47 04-17-2006 08:43 AM
