#1 | |
Start another Oil Thread!
fuel and timing (retard only)
you nailed it sir.
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
crap. Guess its Autronic for me then.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
#3 | |
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
you could probably save more fuel by driving differently then you could by leaning it out 2.5%. my POS Yaris is > * :D |
#4 | |
stop and go air traffic FTL
you nailed it sir.
#5 | |
and what car has a cast iron exhaust manifold?
aluminum pistons?
you nailed it sir.
Mechanic from hell
My S60R has a cast iron manifold, haven't modded my pos yaris yet as it is my daily driver, so I haven't checked to see what is in it.
2007 Black Sand Toyota Yaris Sedan AT 2006 Sonic Blue Volvo S60R AWD 6MT |
#7 | ||
with fragile little aluminum pistons inside the engine don't lean it out.
you nailed it sir.
Mechanic from hell
so if most pistons are aluminum, then why would the Yaris pistons be any different than any other "fragile" aluminum piston when it is leaned out. If that were the case the the 2g eclipse's "fragile" aluminum pstons shouldn't have held up, correct?
and with the exhaust manifold being tubular steel, it would fail -way- before the pistons ever did.
#9 | ||
this still does not account for the fact that a DSM is gonna get great gas mileage because of the turbo, and a 1nzfe is NOT going to gain fuel efficiency by leaning the engine out excessively. do me a favor go drive your yaris around at 19:1 AFR for the sake of the almighty fuel mileage and see how long your engine lasts
you nailed it sir.
#10 | |
because it's turbo is the reason the DSM could safely lean out the engine and improve fuel economy (because he's not leaning out as much as you'll have to on the yaris to yield any gains).
you nailed it sir.
![]() Drives: Future Yaris! Join Date: Oct 2009
You can do it, but not that route. Whoever did that was lying.
Those aftermarket piggyback systems can only control open loop operation, and at "cruising mode" its always closed loop so you have to fool something else (like the signal from the 02 sensor). Now this has to be implemented so it only leans the car out under constant throttle (no acceleration)- otherwise knock will occur and your engine will blow. So yes, you can do it, but only to a certain extent. Honda's "lean burn" system goes up to 25.1 I believe, we could probably get away with 17.1, but I doubt anything else (those Honda engines have specially designed pistons which can burn a much leaner mixture, while we don't (just conventional pistons) |
BTW, also keep in mind that with leaner mixtures you produce considerably more N0x levels, so your kind of polluting more... if you care :D
