Old 09-15-2009, 04:17 PM   #19
o89canucks
Mechanic from hell
o89canucks's Avatar
Send a message via Yahoo to o89canucks
and what car has a cast iron exhaust manifold?
aluminum pistons?
My S60R has a cast iron manifold, haven't modded my pos yaris yet as it is my daily driver, so I haven't checked to see what is in it.
2007 Black Sand Toyota Yaris Sedan AT
2006 Sonic Blue Volvo S60R AWD 6MT
o89canucks is offline   Reply With Quote
Old 09-15-2009, 04:19 PM   #20
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
the manifold is tubular steel.
with fragile little aluminum pistons inside the engine
don't lean it out.
Originally Posted by xnamerxx
you nailed it sir.
Old 09-15-2009, 04:32 PM   #21
o89canucks
Mechanic from hell
o89canucks's Avatar
so if most pistons are aluminum, then why would the Yaris pistons be any different than any other "fragile" aluminum piston when it is leaned out. If that were the case the the 2g eclipse's "fragile" aluminum pstons shouldn't have held up, correct?
and with the exhaust manifold being tubular steel, it would fail -way- before the pistons ever did.
Old 09-15-2009, 04:35 PM   #22
Tamago
Tamago's Avatar
Drives: ZZW30
have you ever seen a 1nzfe piston in person? 1nzfe connecting rod? no? i have. they're fragile, under-engineered.
this still does not account for the fact that a DSM is gonna get great gas mileage because of the turbo, and a 1nzfe is NOT going to gain fuel efficiency by leaning the engine out excessively.
do me a favor
go drive your yaris around at 19:1 AFR for the sake of the almighty fuel mileage and see how long your engine lasts
you nailed it sir.
Old 09-15-2009, 04:40 PM   #23
o89canucks
Mechanic from hell
o89canucks's Avatar
again, I don't tear apart my pos yaris that I drive to work every day to make it a race car, so no. I don't know what the internals look like.
then again, I don't expect a yaris to be an autocross or drag racing machine.
Old 09-15-2009, 04:45 PM   #24
Tamago
Tamago's Avatar
Drives: ZZW30
pot calling the kettle black, you want to lean out a high-compression N/A engine for the sake of fuel milege, because "some guy with a 1993 eclipse turbo did it" thinking it's a good idea.
you nailed it sir.
Old 09-15-2009, 04:48 PM   #25
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
turbo guys usually run higher octane too.
Old 09-15-2009, 04:50 PM   #26
o89canucks
Mechanic from hell
o89canucks's Avatar
I asked if anyone had tried to lean it out for better fuel mileage, this forum is about fuel mileage, is it not? I was seeing if I could get some additional fuel mileage out of my daily driver is all.
Old 09-15-2009, 04:59 PM   #27
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
Originally Posted by Penguin Garage View Post
how much adjustment can the AFC do on the yaris?
2%, 5%, 10%, 25% adjustment?
This is an expensive test to save $40 a tank, but I'd be interested to see it perform.
anyone care to comment?
Penguin Garage is offline   Reply With Quote
Old 09-15-2009, 05:04 PM   #28
RHDVIPbB
the afc increments change depending on what rpm it is. I had an AFC2 on my Conquest and it was a great tool. There is more adjustments you can make. Although I am not sure how the AFC Neo works and what you are capable of doing with OBD2 and up.
Doesn't the AEM FIC allow you to adjust a few different parameters of the motor?
Old 09-15-2009, 05:05 PM   #29
Tamago
Tamago's Avatar
Drives: ZZW30
fuel and timing (retard only)
you nailed it sir.
Old 09-15-2009, 05:10 PM   #30
RHDVIPbB
crap. Guess its Autronic for me then.
Old 09-15-2009, 05:49 PM   #31
Penguin Garage
Drives: Yaris
I'll have to look into it more, but i don't think the piggy backs can adjust fuel enough to make it worthwhile.
you could probably save more fuel by driving differently then you could by leaning it out 2.5%.
my POS Yaris is > * :D
Old 09-15-2009, 06:54 PM   #32
Tamago
Tamago's Avatar
Drives: ZZW30
because it's turbo is the reason the DSM could safely lean out the engine and improve fuel economy (because he's not leaning out as much as you'll have to on the yaris to yield any gains).
you nailed it sir.
Old 10-10-2009, 08:10 PM   #33
basslover911
Drives: Future Yaris!
You can do it, but not that route. Whoever did that was lying.
Those aftermarket piggyback systems can only control open loop operation, and at "cruising mode" its always closed loop so you have to fool something else (like the signal from the 02 sensor). Now this has to be implemented so it only leans the car out under constant throttle (no acceleration)- otherwise knock will occur and your engine will blow.
So yes, you can do it, but only to a certain extent. Honda's "lean burn" system goes up to 25.1 I believe, we could probably get away with 17.1, but I doubt anything else (those Honda engines have specially designed pistons which can burn a much leaner mixture, while we don't (just conventional pistons)
basslover911 is offline   Reply With Quote
Old 10-10-2009, 08:11 PM   #34
basslover911
BTW, also keep in mind that with leaner mixtures you produce considerably more N0x levels, so your kind of polluting more... if you care :D
