Old 10-09-2009, 07:40 PM   #19
frownonfun
frownonfun's Avatar
PITA = pain in the ass
DFCO = deceleration fuel cutoff
WOT = Wide open throttle
IIRC = i have no idea
I crush you like tiny clown car, because you are clown, yes?
Old 10-09-2009, 07:45 PM   #20
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
thanks!
but IIRC is "i have no idea"?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 10-09-2009, 07:48 PM   #21
frownonfun
frownonfun's Avatar
no lol i meant i really have no idea
i'm thinking it means "if i remember correctly" but i'm not certain.
Old 10-09-2009, 07:49 PM   #22
IF I RECALL CORRECTLY
Old 10-09-2009, 07:54 PM   #23
t0m4s
1NZ-FE
t0m4s's Avatar
thanks =)
Old 10-09-2009, 08:38 PM   #24
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
This maybe explains why my car sometimes cuts-off while driving it hard. Hmmm interesting. Any idea on this?
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 10-09-2009, 09:16 PM   #25
frownonfun
frownonfun's Avatar
no the dcfo is when your fuel gets cut off while decelerating in gear... thus saving you gas. as far as getting "cut off" when driving, the only i'm thinking that good be is when you hit 115mph.
Old 10-10-2009, 12:22 PM   #26
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
So I'm back to the same spot, my car cuts-off randomly at 5000-6500rpm in third gear, sometime in 4th and never reaching near 115
Old 10-12-2009, 03:42 PM   #27
t0m4s
1NZ-FE
t0m4s's Avatar
my car was shutting down when i was reaching 140 km/h and let out the gas pedal
Old 10-12-2009, 04:16 PM   #28
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I wonder if any of this is related to the ECU settings being different for the Central/South American markets relative to the US? Of course, Puerto Rico is US, so are the cars US-spec?
Old 10-12-2009, 06:49 PM   #29
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Yes they are US spec. We only get more colors to choose from
Old 10-13-2009, 09:17 AM   #30
hatchbackkid82
Drives: .
Wait Yaris PR, your car is cutting off when you drive it hard and you have the 1ZZFE TB?
Old 10-13-2009, 11:19 AM   #31
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
It has been cuttin off with and without the 1zzfe TB. That's the problem, cause if it was only with the 1zzTB I would blame the TB, but it has done it with the 1nzTB also.
It cuts-off the check engine lights blinks for a few seconds. The light goes off and the car continues normally. I think my car is a real biatch!
Old 10-13-2009, 11:40 AM   #32
hatchbackkid82
Drives: .
what? damn i don't even know what to tell you. i was going to say that it could be the 1zz tb but if it's doing that stock...then i don't know. Anyone else have any idea what may be causing this?
Old 10-13-2009, 01:59 PM   #33
t0m4s
1NZ-FE
t0m4s's Avatar
scangauge? any code? maybe it's a leak or gasket or a sensor
Old 10-13-2009, 02:13 PM   #34
ozmdd
ozmdd's Avatar
What other parts of the car have you changed/moddoed in the past? this sounds like it might be something screwing-up one of the sensors.
Old 10-13-2009, 05:57 PM   #35
advocate
Drives: car
Originally Posted by t0m4s View Post
sorry but
what's PITA? DFCO? IIRC? and WOT?
Pain in the ass
Decelerating fuel cut off
if i recall correctly
wide open throttle
Old 10-13-2009, 07:45 PM   #36
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Maybe u people can help
Maybe it has to do with my custom intake, maybe.
My mods:
-Intake
-Underdrive Crank Pulley
-Header
-2" custom exhaust (only 1 cat deleted)
-1zz TB (its on right now, but as I mention, it has done it without the TB)
-Nothing else for now
I haven't scan it because the CEL goes off as soon as it gets back to normal.
This might be a good mystery to solve.
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
Intake for the 1ZZ throttle body? fuji Performance Modifications 9 06-14-2009 12:02 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
